My spies tell me they saw snowman today and he got 240@all 4 on Sti Dyno...
PS: My spy "mate" got 210 in his Black Sti 03, with the stock wing. But be careful coz in two weeks time this thing will be pushin around 250@all 4...
Spewing I didn't come down, would have helped if I knew about it :) I jeard a Monaro got the highest with 250kw??
The rumours are false!
I went down to say Hi to Brandon (beefy) and Cazz and a few others but didnt run my car on the dyno.
There were a number of great cars down there - some very impressive STI's, the Oz delivered yellow Nismo S15, a JDM interga, and a whole lot more inlcuding some skylines. It was my first visit to the facilities at STI docklands and I must say its a very impressive set-up.
Meshy - the event was posted in the events section. Maybe you should look in there one day! :)
You should have stuck it on Andrew. Did the monaro really get 250atw then? I'll have to keep my eyes open for the next one... should be fun, by then I predict a blue R34 with Nismo LMGT4 clocking around 450kw at all fours :( that'll stick it up the WRX hoons :D
Dont recall seeing a monaro - but a Falcon GT got 240 I think. I wasnt there for long to be honest which is why I didnt run. Had other things on that day.
There were 2 new black STI's - both were awesome.
And stop exagerating what Im doing to my car! Your going to dissapoint a whole lot of people at this rate! lol
highest reading i saw a rex produce on the day was 196rwkw and that was after cranking in an unsafe amount of timing.
You sure there wasn't a Black Sti 03 with a stock WRX boot wing on the dyno that made 209kw?? For some reason it doesn't suprise me my mate is full of sh!t. Always bragging how him and his mates beat GTR's... but they could'nt come close to me when I had 270at the rears.
I'm not totally sure as i wasn't there all day, if snowman's had a very short haircut then i was there for about an hour after he left. Speaking to people that had been their since the early morn no rex's did over 200. It was Vinny's personal car (black sti) that i saw run 196 after he had the luxury of playing with the timing - then reset it to a safe level b4 leaving the dyno. Vinny told me there was a tough GT (XW or XY) that ran 225 odd in the morn.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
