Also guys I'm not a forum trader and I don't know if any other traders for SAU are Garrett distributors as I haven't had time to check but I can't sell you stuff here and I cannot advertise prices here as it's not fair for those paying money to do business here.
I have and always will look after SAU paid club members (from ANY state) but please understand if I don't plaster prices everywhere here as there is a reason for it. I have been involved/helping the club for 10 years now but I can feel the ever watchful eye of Nismoid burning into my ass right now :P
  • Replies 70
I have a compete spare engine witch im building from top to bottom I just brought today a Hks 2.8l stroker kit should be here soon as I ordered express and yes im willing to trial fit them the gte is currently not relocator as I removed the stock engine for the project so let me know if your stop intrested as im about to buy all the cams caves zia cams springs ect
Say wut?!
Elite racing is so helpful. Thanks so much Daniel coral your help im thinking we go the gte 2860 and is it ok .5mm over size valves or 1mm acl I lose out response big time I forgot to ask if it will make a massive difference can wait till I get the 2.8 thanks again Daniel you helped me out so much highly recommended and highly appreciated
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
