Hi people, just wanting to hear peoples thoughts on High Octane coatings. I have used Competition Coatings, HPC, Jet Hot in the past and have my thoughts on the respective pros and cons of them....I have not used High Octane coatings in the past.
Anyone used their black manifold/turbine housing coating and can speak to its durability?
http://www.performancecoating.com.au/turbocharger-coating
My own experience has HPC the best for quality and durability...no surprise they are they most expensive. Competition Coatings and Jet Hot about the same, with perhaps Jet Hot being a tad more durable but less range of colours and finishes.
I've used Techline ceramic coatings on my manifolds and turbine housings on 2 of my cars. Coatings are inside and out of the manifolds and turbine housings.
I've proven the coatings hold up to sustained heat around 850 degrees no problems. Looks good too. I don't know who of the companies you mentioned use the techline products, but the key is in the application. I have an aluminium oxide/ceramic base under the black TurboX coating.
Competition Coatings did a set of CP pistons for me in one of my other engines. The finish looked great. Never produced any performance data with that engine though. Changed the recipe before getting that far.
I used a local ceramic coating a few years back. The ceramic held up but i swear the black that i paid extra for was just heat proof paint. After tuning on the dyno the black was peeling off from the collector.
ive used competition coating for my manifold and turbine housing, the high temp black one,
seems to have reduced my coolant temperature a fair bit , could be the larger turbo contributing though, seems ok so far.. not fancy to look at though, just faded black looking..
craved coatings did mine too, after a couple of dyno pulls the exhaust housing was measuring 300c on the surface (manifold and housing ceramic coated a cast iron/gunmetal grey colour inside and out)
competition coatings did both my manifolds, both sides of my turbo, cooler piping, TB and dump pipe.... looks sick and works really well... Ive got a few lines which are really close to my dump pipe and im so supprised that they havnt melted... without the coating im sure they would have.
All encouraging, but how long have you been running the manifold, turbine housing coatings. This ca is driven around 1000kms a month and does some sustained wide open throttle stuff so will get plenty of heat in it doing some fun days at the track. I have decided will be givign Comp Coating a go in Coburg and see how they go
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
