You've missed the point though. This is about rebranding the vehicle as an Infiniti, not a Nissan. Mine came with the Skyline mats but they're a little worn and I'd like to replace them with Infiniti mats instead.
Where did you get the engine cover? Struggling to find it.
  • Replies 123
Posted Images
Anyone know if we can get the Infiniti grille emblem for our cars? I know the Nissan ones can be taken off. Do the Infiniti ones fit the same, and where can we get one?
I'd say it'd just be a swap, try Ebay
Definitely eBay. Around $30 should do the trick from memory. The Infiniti badge is a little more elliptical in shape so there will be some of the grille that used to sit behind the Nissan hamburger that will then become exposed. This is all ok but you might find there's a buildup of dirt that will need a good wash and possible hand polish to basically make sure there aren't any unsightly marks when you replace it.
Not really cos if you trawled import monster you would find that there is infiniti branded and completely non branded stuff for the V36 (lots of non branded mats for instance). I don't get the whole rebranding thing, if you bought a Skyline for the resale value then you've pretty much missed the point IMO, but each to his own I guess. The only good thing from Infiniti arriving is the hope that my satnav can be upgraded.
^^ they might fit.. but you can be sure the markup the Australian dealers will put on them will be far more than the shipping costs from USA.
Yeah i'm guessing the dealers here will be more expensive. Might as well get them shipped. Do they fit well after i take the hamburger off though or do they look dodgy?
Ah, so they do have Infiniti branding eh? I'll trawl away then. Cheers. As for the whole rebadging thing, I've already explained myself before in this thread ... purely aesthetic. Nothing to do with resale value at all since I get attached to my vehicles. I wouldn't have bought this car if my J30 Maxima wasn't written off.
Have you read post #105 in this thread? Look up so I don't have to appear like a broken record.
Completely agree with you on resale value... There may be a small increase, but you wouldn't do all that work for the sole purpose of resale.
i know its not relevant in this case, but my thoughts would be:
id assume most of the population would see the exotic INFINITI as the proper brand since it is in the showroom, and see nissan as the asian imitator... and then get put off by seeing "boring old nissan" on the vin plates, relating it to a cheap copy of a good car. much like the old VR commodore/lexcen thing where people put commodore badges on the outside. it was still the same car but nobody wanted the lexcen
But also in saying that, the "old school" skyline and JDM obsessors will still know what it is and i'm sure when Infiniti goes on sale here in Oz the Sales people will be educated that they are in fact Nissans and will more than likely be told to explain this to customers
Ahh right sorry mate. There's quite a few online advertised for G37 and G35 sedan should they all be the same or do they differ?
Edit: i meant G35 and G37 Infiniti grille emblem
Edited by Marshan
G35 has the 3.5L engine.. G37 has the 3.7L engine.. infiniti model numbers signify engine size.. not series.
G35 = 350GT
Based on the vehicle in your profile here, that's what you need to aim for. I'm not really sure if there are any differences with the grille emblems but it's best to play it safe.
Sorry Greg i should have been more clear. I was talking about the Infiniti grille emblem. Not sure if they were the same for the G35 and G37. I asked the seller if the G35 sedan Infiniti grille emblem was the same, he said he's not too sure.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
