100% sounds like a bearing.
Stop running the engine before that bearing disintegrates and costs you a lot more in the long run.
An engine build doesn't have to cost you stupid amounts of money either, it's about buying from the right places and not getting screwed on machining and assembly costs.
  • Replies 90
ok so there is no good performance mechanics within 100km of me, i have to get the car into sydney to have it rebuilt, i live on the central coast so if anyone knows a shop that can diagnise it and check it all out plz let me knw.
I paid 39k for her + on roads from outerstate cost me 45k in the end, i had the car checked by nissan they pulled turbos off compression test ect, but i guess i have oil starvation at high speed.
Thats very unfortunate mate sucks when things like this happen.
Might as well go forged pistons at the very minimum while the motor is all out imo accompanied with new water + oil pumps, oil restrictor and a sump baffle as you would be silly not to.
I remember when doing mine I had the car dropped the car off Saturday morning, picked it up 2 and a half weeks later with all machining, assembly done and few other goodies I dropped off installed and a retune. A year later my car is still going hard and pulling rather respectable power figures with no issues and the motor runs beautifully. If you want details etc shoot me a PM I will be more than happy to give you some more info
Ps. Why on earth would you make your GTR a daily, thats just asking for trouble lol !
would have to agree with this 100%.. its not impossible, but far better if you dont have to rely on a car like this as your primary mode of transport unfortunately..
keep us posted, best of luck to you mate..
Sorry to hear this Adam, i was looking foward to seeing this on a cruise.
I do suggest buying a daily - even its the cheapest nastiest thing you can find - it would be a shame to sell the car as is.
If you start looking for an engine builder, i suggest Paul at Red R Racing - his reputation speaks for itself - if you want his details, shoot us a PM.
Duuuude im at somersby. Give me a msg 0414879711
Car is with Tuff Tune at tuggerah, its big end, looks like im going to be doing ACl bearings, baffle, N1 oil pump and putting it back togeather, ill probs get timing belt and water pump done while its out also, dont have the cash flow to do pistions and shit now, if it only went in 6 months and not right after i bought it.....
yeh thanks man, if i have any issues with tuff tune i will 100% be giving u a call tho its good to know we have ppl on the coast that can look after the great Godzilla.
a big thanks to everyone also for help diagnosing the issue, the advice on the tow truck probably saved me a crank also so cheers everyone its appreciated.
Edited by T4NK
I really cant express oil control enough! The day my engine comes out, oil control will be the first thing i do
This. When you consider you can get a Tomei Sump Baffle and a Oil Restrictor together for $300 you would be silly not to do this as a minimum. Such a cheap mod that goes such a long way
Hello,
Did the Nissan inspection come with any form of warranty? I know with state roads inspections, if they fail to pick up a fault, they will pay for a % of the repair.
Its a long shot tied in with a little bit of wishful thinking, but thought i'd mention it incase it does help.
yep i was just quoted around 2.5k to pull it out do the bearings put it back in, and 7k for a full rebuild with baffle and restrictor, im thinking maybe i should try a diff shop for quotes all i really want to do is prevent this from happening again i dont need to put forged internals in the car as im only running it stock and dont have plans for massive KW i bought the car to drive it stock not to pack $$$$ into the engine to make it fly. Jez what do u think of this price wise? and does anyone else konw any good shops in Sydney/central coast i can talk to?
Hey guys, im just wondering what would need to be replaced in the engine besides the bearings as they are shagged if i was to keep stock internals and do oil management (baffle and oil restrictor and N1 pump) this is all i feel i really need to do as im not going to use it to break land speed records.....yet :D
This was my list so far
N1 oil pump $350
Water pump $150
Baffle pan $350
Timing belt $100
Head gasket $260
Restrictor $3
ACL bearings $300
ARP Head Stud Kit $300 (not sure if i will need this or not)
Edited by T4NK
Fingers crossed you havent damaged the crank!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
