Pizza Cruise - The Return.... Friday August 17Th.
  • Replies 101
Looking forward to meeting all the new members and those who have been around for a while too.
After a meeting with the venue's management today, they have agreed, although it's not part of their menu, to make special "SAU pizzas" !!!! :thumbsup:
There will be a choice of three different ones to start but chef Shane is more than happy to make to order so a big thanks to THE PALMS crew for being so accommodating.
Whilst there i though I'd take some pics so you get the idea of what to expect...
This is one of the entrances to the venue
The car park in all its glory
The courtyard that looks directly onto the above mentioned carpark
And the dining room with pool tables and a HUGE bar.. there are also gaming facilities for those who want to have a bet.
So there you have it, it's shaping up to be a great night :banana:
Yes, the cruise part is relatively short, it's all about the get-together really so, happy to hear you'll be joining us..
We'll meet here...
And since my line is not finished yet, I'll be driving this...
:cheers:
:cheers:
Dooo it Marsbar, I'll be in the VE.. cruising in sporty style..
Hey mate, killed my clutch so i wont be making an appearance as planned :/ will be in on the next one though!
Oh you lameo, just scam a lift or szomethin.. :D
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
