I had originally planned to purchase a few more items this month, but unfortunately the realities of life stepped in and, well....BILLS!!
But I have a little bit of budget left over and looking at buying the following, so am currently looking around:
1. either GT2530's or N1's
2. Coilovers
3. Power FC or F-con Pro
4. Adjustable cam gears
I was looking at an exhaust system but out of budget for now. Oh and wheels of course as they are stockies. Looking at a set of BBS LM's.
My car is stock (R33 GT-R). Coilovers are a must as 3 struts are leaking as found in the last service.
I have been looking on ebay etc. but if anyone has anything that fits my shopping list and they are looking to sell shoot me a message.
Does anyone have any idea how much this all may cost to get installed once I buy it?
Cheers.
Few holes in there. HKs gt2530s for 400+kws or n1/2860-7 for a touch over 300
A turbo swap on a GTR won't be cheap and will probably eat up all of your budget
Don't get an f-con no one can tune then in Canberra (only hks pro dealers can and closest one is in Sydney or Brisbane)
What suspension are you looking at getting? You get what uyou pay for
Bigger turbos will need bigger injectors, there is no point getting the turbos fitted and the ecu tuned only to have to retune again when you want more than the 280rwkws or do the standard ones will give, a bigger fuel pump is a must have and factor in z32 or nismo afm's they run out of resolution at around 300rwkws
Also factor in a new good quality front pipe, plus might as well change the dump pipes while the turbos are out, a 3 -1/2" exhaust or better, you might also find the ignition system isn't up to the task.
The way I would do it,
Ecu, front pipes and cat back, suspension, fuel pump and mantinance eg new ignition coils
Have it tuned At STANDARD boost on the stock turbos to make sure they live a while, whilst saving for the new turbos injectors, afm's etc
Hmmm...I have about 4-5k all up at this point.
Looking at a good condition second hand pair of HKS coilovers from a member on here.
How much is it to swap the turbo's?
Edited by Deziner
Ahk. I can't say I have ever heard any thing good about the HKS suspension
The BC coilovers whilst cheap are meant to be quite good and for all accounts are the same as the GReddy type S stuff, plus they will be brand new
So your 5kbudget will get you those, get some new white line sway bars too
Will leave you 3k, so a nice set of 75mm front pipes and a 3 -1/2" exhaust will be a little over a grand
A 2nd hand pfc will be ~1000 and should leave you enough for a tune
Or leave the ecu and get some wheels :)
To buy and fit the turbos you will have no budget left or very little
So without upgrading the turbo's and doing the exhaust system and ecu what sort of extra performance would I be looking at?
Its currently making 222awkw and its stock except boost restrictor removed and boost set at 10psi and CASA has been spun.
I guess my main reason for wanting to do the turbo's is because of the ceramic standard turbo's and concern if one blows etc. Not sure if I can bump the boost up more than it currently is?
Also can anyone recommend a good complete exhaust system and where to buy them here in Canberra?
Edited by Deziner
If you are buying garrett turbos or bc suspension, get in touch with street to track. Has the best prices I've come across
Exactly the link I was going to post
Spoke to him yesterday and he quoted $1135 for a set for my 33 and my neighbours 34 posted to same address.
Prices are even better if the AUS dollar gets better
So I think this is what I have decided on:
  • Front pipe
  • Cat back
  • Apexi Power FC
  • Adjustable cam gears
  • Coilovers
This will leave me about $1400 left over. Anyone have any idea whether this will pay for the install of these items?
Maybe we could do a 3 way buy and get the price down even more?
Guessing you live in the ACT so we could get all 3 sets posted to the one address..
Let me know if your interested I will be ordering mine in the next month
Shipping is quick through him as well.
But I doubt you will get them any cheaper getting them all posted to the same address. The coilovers and the box they come in weighs 45lbs and they are shipped via ups so it's expensive regardless.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
