I had originally planned to purchase a few more items this month, but unfortunately the realities of life stepped in and, well....BILLS!!
But I have a little bit of budget left over and looking at buying the following, so am currently looking around:
1. either GT2530's or N1's
2. Coilovers
3. Power FC or F-con Pro
4. Adjustable cam gears
I was looking at an exhaust system but out of budget for now. Oh and wheels of course as they are stockies. Looking at a set of BBS LM's.
My car is stock (R33 GT-R). Coilovers are a must as 3 struts are leaking as found in the last service.
I have been looking on ebay etc. but if anyone has anything that fits my shopping list and they are looking to sell shoot me a message.
Does anyone have any idea how much this all may cost to get installed once I buy it?
Cheers.
Few holes in there. HKs gt2530s for 400+kws or n1/2860-7 for a touch over 300
A turbo swap on a GTR won't be cheap and will probably eat up all of your budget
Don't get an f-con no one can tune then in Canberra (only hks pro dealers can and closest one is in Sydney or Brisbane)
What suspension are you looking at getting? You get what uyou pay for
Bigger turbos will need bigger injectors, there is no point getting the turbos fitted and the ecu tuned only to have to retune again when you want more than the 280rwkws or do the standard ones will give, a bigger fuel pump is a must have and factor in z32 or nismo afm's they run out of resolution at around 300rwkws
Also factor in a new good quality front pipe, plus might as well change the dump pipes while the turbos are out, a 3 -1/2" exhaust or better, you might also find the ignition system isn't up to the task.
The way I would do it,
Ecu, front pipes and cat back, suspension, fuel pump and mantinance eg new ignition coils
Have it tuned At STANDARD boost on the stock turbos to make sure they live a while, whilst saving for the new turbos injectors, afm's etc
Hmmm...I have about 4-5k all up at this point.
Looking at a good condition second hand pair of HKS coilovers from a member on here.
How much is it to swap the turbo's?
Edited by Deziner
Ahk. I can't say I have ever heard any thing good about the HKS suspension
The BC coilovers whilst cheap are meant to be quite good and for all accounts are the same as the GReddy type S stuff, plus they will be brand new
So your 5kbudget will get you those, get some new white line sway bars too
Will leave you 3k, so a nice set of 75mm front pipes and a 3 -1/2" exhaust will be a little over a grand
A 2nd hand pfc will be ~1000 and should leave you enough for a tune
Or leave the ecu and get some wheels :)
To buy and fit the turbos you will have no budget left or very little
So without upgrading the turbo's and doing the exhaust system and ecu what sort of extra performance would I be looking at?
Its currently making 222awkw and its stock except boost restrictor removed and boost set at 10psi and CASA has been spun.
I guess my main reason for wanting to do the turbo's is because of the ceramic standard turbo's and concern if one blows etc. Not sure if I can bump the boost up more than it currently is?
Also can anyone recommend a good complete exhaust system and where to buy them here in Canberra?
Edited by Deziner
If you are buying garrett turbos or bc suspension, get in touch with street to track. Has the best prices I've come across
Exactly the link I was going to post
Spoke to him yesterday and he quoted $1135 for a set for my 33 and my neighbours 34 posted to same address.
Prices are even better if the AUS dollar gets better
So I think this is what I have decided on:
  • Front pipe
  • Cat back
  • Apexi Power FC
  • Adjustable cam gears
  • Coilovers
This will leave me about $1400 left over. Anyone have any idea whether this will pay for the install of these items?
Maybe we could do a 3 way buy and get the price down even more?
Guessing you live in the ACT so we could get all 3 sets posted to the one address..
Let me know if your interested I will be ordering mine in the next month
Shipping is quick through him as well.
But I doubt you will get them any cheaper getting them all posted to the same address. The coilovers and the box they come in weighs 45lbs and they are shipped via ups so it's expensive regardless.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
