As the title says, I have a couple options and can't seem to decide which is the better option. My car is a stock R33 GTR except for boost restrictor removed and the CAS has been spun.
I have a limited budget of $4000 and will be buying all the parts second hand (mostly from SAU member here).
The option I have in mind are:
Option 1
  • Coilovers (I have 3 leaking struts that were found in my last service)
  • Front pipe
  • Power FC
  • Adjustable cam gears
This will leave me around $1900 out of my budget for install.
Option 2
  • GT 2860's including gasket kit
  • Dump pipes
  • Power FC
This will leave me about $1580 out of my budget for install.
Firstly, Does anyone know whether my left over budget would even cover the install of either option? If not then I need to rethink what I am going to do.
Secondly, which option do you think is better. Option 1 fixes my suspension and gives me some performance gains. Option 2 sures up my turbo's (going from ceramic to steel wheeled), and I guess in doing so protects my engine longer term.
I never thought it would be so hard to decide what to spend my money on!! LOL
Cheers.
Option 1
  • Front pipe
  • Power FC (pointless since you'll be driving around on a untuned basemap, stock ECU handles 1 bar on stock turbos without a problem)
  • + Highflow cat
Option 2
  • GT 2860's including gasket kit (-9s, -7s, -5s?) + oxygen sensors (might as well do them while the turbos are out) + adjustable wastegate actuators if the new turbos don't include them. Looking at about approx $900 in install by a workshop (8-9 hrs)
  • Dump pipe (keep the stock dumps for 350kw and less)
  • Power FC
  • + Highflow cat
Normally I'd say go the handing... BUT... GTR turbos failing, will have the risk of taking the motor with it.
So swap out the turbos (-7/-9), and get a tune. Be warned though the stock clutch won't last forever if you push 300rwkw. IF you just keep the turbos @ 1bar for the time being you'll be better off however.
I'd be fixing the suspension first
Then upgrade your exhaust,cam gears and PFC with tune
Also have your turbo shafts inspected and run say 12psi to preserve them
That's what I reckon
^^^What he said. If you smash the car up it won't go very fast at all. If the PFC is a good buy put it in your garage until you can afford to do the turbos and get a tune.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
