Okay I came back because I feel bad...
Bike sounds like a good idea.
Do what I am currently doing and for lunch cook up some chicken + broc
If you prep your meals it will help you A LOT!
Keeps you on track.
The days I dont prep I find myself going ehh may as well just get this.
and look down and I am eating some fat burger
My biggest problem...
Dont like any vegetables.
Salads, sort of ok, but not veg.
Closest i get to veges, are hot chips, because theyre potato.
Used to be the same on the vegetable subject.
Then I became a man.
It's no longer an issue.
This. Have had brocolli/cauliflower boiled for dinner maybe 3-4x a week for the past couple of years, minus 3ish months (binge).
Do it, after a while you'll get used to it... :yes:
im competitive and like numbers so install 'runkeeper' and use it to improve your walk/run/ride.
Disclaimer: the furthest ive gotten is installing the app :)
thanks.
is that for iphail, android, or both?
I had an app called noom that wasn't too bad, might have to get it back
  • 3 weeks later...
Ok, back in the band wagon, exercise wise.
still eating crap.
went for a 2k walk yesterday arvo.
today was a 1.6k walk, the 30mins on the cross trainer.
feeling pretty good.
cracked the 1.5l mark of water intake, considering I normally only drink soft drink, this is quite an achievement for me.
  • 4 months later...
  • 4 weeks later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
