  • Replies 90
Well thats good for ya. Glad you're selling sme stuff, seemed to have been going a bit slow for ya even though eerything was priced well.
Yeah most of the popular bits went quick now it's leftovers...had a lot of useless people however-contacting wanting prices/pics/freight quotes and some silly lowball offers...there's a lot of time wasters out...held onto the brakes and hubs for a couple months for someone who turned around after turning down a few sales to say he didnt want it..
Hey do you have the engine under tray and the bolts for the water pump.
Sent from my HTC One XL
Sorry mate don't have either of them
I need all the plugs that connect onto the auto, so the speed sensor plug, reverse switch plug and the neutral switch plug... all from the car side, not the tranny side...i cut mine off when removing the auto for some reason... if you have those name a price and pack em up coz ill grab them
Wana flip me a text with ur number and il mms u a pic of what I have-I'm pretty sure I've got what ur after-0419837474. Bonnets gone I'm sorry
No aircon facia or vents sorry
Tail light from gtt four door- different with two doors.
I have the glass but I'm reluctant to split and post to Canberra with risk of breaking and leaving me with an incomplete door sorry
  • 2 months later...
  • 4 weeks later...
Ill offer $40 posted on triple gauges. Shouldn't cost more than $5.50 to ship (in a small prepaid satchel) :)
Have you got the front wheel arch liners?
Yes but not perfect condition-if u send me a mobile number I can mms a pic
Do you a left hand mirror and the motor that drives it to fold in and out?
Have left hand mirror. My understanding is mirror motor is in the mirror.
Triple gauges sold sorry
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
