R32 4Door Part Out, 2Way, Cage, Tein He, Cusco, Apexi, Greddy
No lowballs please
R32 4 door rolling shell, pearl white, Mod plates for rollcage, rb25 motor and manual box.
Nardi s/wheel, most of interior, bosch 040 f/pump, HEL braided brake lines, RB25DET loom, hicas lock bar.
Stock brakes, suspension and arms, 16x7' stagea wheels, Big battery in boot and new stereo.
Currently has 6 months rego with 327AXI plates,
No motor, box, diff or shafts, No bonnet or front bar, No front seats or rear sway bar.
$3500
Safety21 R32 4door 5seat rollcage, 6 point bolt in with padding.
Rare as and minimal intrusion, Hugs window line and even had baby seat in back!
$1000
Tein HE Driftmaster coilovers
8k-6k Two way height adjustable
Damper adjustment
$800
Nismo 2 way LSD, R200 non abs housing with 4.3 gears, 5 bolt shafts included
Always spins 2 wheels!
$700
Big Brake Kit suit R32 or silvia
DBA 4000 slotted GTR brembo 328mm rotors
Unique autosports caliper adaptors/dogbones
All near new
$750
Cusco rear upper control arms
Adjust your camber bro!
$250
Cusco R32 GTR 30mm rear sway
Includes Solid links
$250
R32 GTST front upper control arms
Solid & Adjustable, Bearings replaced.
$250
RG front tension rods
Castor adjustment and solid
$150
R32 GTR plastic front bar, lip and grill
Few marks on bar, lip ok and all black.
$500
R32 GTR alloy bonnet
Been modified to fit 30
Cheap and White
$300
R32 4door Mspec side skirts
Few marks and Plastic
$200
Sabelt GT1 fixed back seat x2
Black in very good condition, FIA approved
$650
2x bottom mount seat brackets suit R32-33
$250
Apexi Power FC suit R33 RB25DET
Hand controller, Z32 air flow meter and K&N air filter included
PITS tune for GT30r, 750cc, Z32, plenum & 80mm throttle.
$1000
Splitfire coilpacks suit R33 series 1 & GTR
$350
Nismo 750cc injectors
Standard fuel rail modified with extra fuel feed.
$650
T67-25G 10cm kando, Tial MVR 44mm, manifold, dump and screamer
Turbo only few months old, still under warranty
Wastegate mounted off exhaust housing and includes flanges and flex for plumback
Stainless hi mount manifold, mild dump and screamer
$1250
Greddy GREX oil cooler kit
Includes filter relocator, big cooler and thermostat.
New lines fitted 6 mths ago
$550
R32 40mm Alloy Radiator & 16' electric fan
$220
R32 4 door 3' exhausts
Race - full 3' twin 3' tips, no mufflers
Street - Full 3', big rear stainless muffler
Twin 2.5-3' rail slider front pipe & std cat
$450
Twin bosch 044 fuel pumps, big surge tank and 8mm fittings
$450
More to come!
Sam 0423 648 114
Gold Coast
Edited by 32TAXI
Spares:
R32 4 dr Bootlid, no holes or dents, white $80
R32 4 dr series 2 tailights $150
R32 projector headlights $150
R32 centre console and lid still attached $50
R34 GTT 4x 17x7.5 Wheels, 2x good 235 tyres $200
Open to offers
Edited by 32TAXI
Sell me ur rear window? Lol
Just build a another one lol - shell, cage, coilovers = $5k + your motor, box,diff, seats, bonnet and bar!
splitfires, gtr bar n 4dr skirts SOLD
Edited by 32TAXI
Leyt me know if sale falls through on headlights mate, super keen, wouldn't be willing to sell indicators as well? Cant find a decent set anywhere!
Would you freight the tail lights to WA?
Yes, Freight no probs, best PM me for details
All still available:
PowerFC and Z32 afm $1000
T67-25g+Tial MVR+rb25 mani,dump and screamer $1250
Tein HE driftmaster coilovers R32gtst $800
Nismo 2way R200 non abs 4.3 gears 5 bolt shafts $700
Front upper adjustable control arm R32gtst $250
Cusco Rear upper adjustable control arm R32-S13 $250
Cusco Rear sway bar+solidlinks 28mm R32GTR $250
DBA4000 328mm rotors & UAS adaptors R32-S13 $800
bump for a a seriously straight body 4dr!, btw very happy with the bar and skirts, cheers mate :)
Thanks Guys, Very uphappy to see it go!
R32 4door complete car less drivetrain, front seats and front bar $3000ono (modplated LH8,LO1,LA1,LK6)
Add a 6 point rollcage $1000
And "coaster's" RB25DET manual conversion $1650 = legal fun!
Edited by 32TAXI
Shell, Cage, Turbo, seats & radiator Sold
Whats left:
Cusco rear arms $250
Cusco rear sway bar $250
R32 twin front pipe $150
R32 3' straight catback $200
Big Brake rotor kit $700ono
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
