I have a S1 Stagea RS4 auto with the under dash hand brake + release handle, I've just had the rear brake pads replaced and last night I noticed the (!) symbol flickering on & off whilst driving.
Is there a sensor for this light? Or do I just need to find the hand brake cable and apply some grease?
Any thoughts?
https://www.sau.com.au/forums/topic/406053-sticking-hand-brake-light/
actually, it is more likely to be low brake fluid - the handbrake light is also used for that.
Have a look at the fluid level in the large resoviour in the engine bay near the driver's a pillar. If it is low you either have a fluid leak (bad) or your pads and discs are low and ready for replacement
Aren't there two resivours and if so where are they, i know the one near the break booster but someone was talking about one below there or something. I think i have this same problem or at least i hope it's this simple!!!???
sorry I wasn't very clear - the warning light is either handbrake on or low brake fluid, and low brake fluid only happens from a leak or sometimes pads worn.
If you have plenty of fluid in the master cylinder, it must be the handbrake switch not releasing properly.
Thanks Duncan, I'll have a look to see what I can do!?
  • 1 month later...
Has anybody located the switch I'm referring too?
Any thoughts?
The switch should be on the rearward side of the foot brake you use for parking. Its a peg type that extends out ward to form the earth for the circuit when you depress this lever.
Having rear pads replaced wont help your park brake position as the park brake is the internal hub type (Pretty sure). If you have noticed an improvement in your park brake its possible there has been an adjustment made to your cable under the dash rather than at the rear wheels.
Could be the switch has been knocked loose?
Try releasing the park brake then get your toe under the pedal and pull it back a bit.....
I still have the same problem. At first I had to put my foot under the pedal to make it release, then it stuck altogether.
I fixed it by disconnecting it. Maybe one day I will try again and also make the ABS light go OFF.
Which cable seizes? Is it the one from the dash to the splitter, or one of the wheel cables?
Generally, the inner sheath rusts and damages the plastic coating on the cable, which makes it jam. No amount of lube down the sheath will free them up.
I know it's pretty obvious, but if you can work out which cable it is; there are companies that can manufacture factory style, plastic coated inner wire replacement cables.
I'm sure Nissan replacement cables will be fairly pricey.
The rusty cable may be the answer I am looking for. The 25G came from a salty road area in Japan. While repairing the smash damage we found several patches of quite serious rust and had it all cut out and repaired. Soon as it is driveable this week will put it on the hoist and check it out.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
