New thread with pics. (mods please delete old thread
Parting out a complete 33 gtst with nice mods. Some stuff has been sold, listed below is whats available.
bigger items are pickup only, will post smaller items at buyers cost. I am located in Ipswich qld and can be reached via pm or ph. 0413863207
I will be attending superlap in sydney next week so some items depending on size can be delivered personally at the event.
Some parts ore not pictured. a brief list below
RB 25 engine, only, no ancillarys. good engine maintained byy ERD....800 dollars
RB starter motor....100 dollars
Power steering pump ....100 dollars
Alternator.....75 dollars
Air con compressor.....100 dollars
HKS Hyper D coilovers in excellent condition complete with external adjusters for the rear and c spanner and adjustment tool.....650 dollars
SUB Zero plenum with ford throttle body, tps, Lobster tail piping with tial 48 mil atmo gate, These pleums have been used to make big power and retain the factory runners to improve response and mid range.....750 dollars or will seperate
Very clever catch can with speedflo fittings and braided lines. There is an atmo tube running up underneath so as to remaiin stealth and defect free.....125 dollars
speedo cluster sold subject to payment
complete hot side consisting of near new bmc 4 inch filter to garret 35R turbo with .82 rear housing, Sub zero low mount manifold, sub zero 60 mil wastegate plumbed back, custom dump, turbo to intercooler custom piping, all oil and water lines (mostly braid, Full 3 inch exhaust with near new cannon and steel cat.
Absolutely complete hotside upgrade with all quality gear ready to just bolt straght on to a 33 gtst....BARGAIN!!!.....2000 dollars
As new cooling pro 100 mil intercooler suit gtr or gtst, perfect condition.....250 dollars
Unmolested front reo from series 1 33 gtst, clear those defects....200 dollars
Genuine nissan m spec sideskirts, passenger side needs a small plastic repair but otherwise excellent.....125 dollars
Factory pods in mint.....100 dollars
Nismo 550 sidefeed injectors in 25 fuel rail, no issues at all....500 dollars
dash surround, I have 2 in good condition.....50 dollars each
Clear rear garnish (2 again) .....40 d0llars each
rb25 coils and coil loom no cracks or faults.....100 dollars
Series 1 antenna.....50 dollars
the little tray thingy that goes under the climate control, again I have 2 of these....20 dollars each.
drivers side electric window reg.....75 dollars
cas......75 dollars
Indicator, wiper stalk....50 dollars
pair of series 1 headlights in good nuck, just need a polish, (i can do it)....250 dollars
Genuine greddy boost guage in greddy pillar pod.....150 dollars
as new handbrake and gear lever boot red stitching inc gear surround plaastic with lighter.....40 dollars
33 climate control in good working condition.....50 dollars
drivers side window motor, (I have 2) 100 dollars each
As brand new mongoose alarm with all sensors and switches plus the 2 remotes. Only been in car a very very short time.....200 dollars
full lock and key set for 33 gtst inc both door barrels, ignition, and boot barrel....100 dollars
rb25 engine, good nick, maintained by ERD......800 dollars
18 inch dtm rims 8 and 9 inch with khumo ecsta xs tyres in 265 rear (50%) and 235 front (90%).....500 dollars
you asked the right bloke mikey, yes they will, the only difference between the 2 is a screw on spacer block on the back of the gtr lights, just unscrew them and screw them on to the gtst lghts. excactly the same light in all respects.
Hello,i would like the skyline rear garnish and the climate control face,can come up to sydney and pick up.
Let me know when and where please.Cheers genelle. :cheers:
you have a pm.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
