Sau Vic 2012 Motorsport Championship Round 6 - Winton 1St Sept
  • Replies 156
Posted Images
Had a very bad start to the day....
Intercooler hose popped first lap, and then it popped again on the first lap of the second session....
This is the results of 5m flames
Once we got all the sorted, had a blast!
Thanks to Richo, Rob and the guy with the hoses & zipties for helping me out!
Very happy with my times today, once I started to grow some balls
what a great day! first time at Winton and definatley worth the drive. I dont think you could ask for better weather, crisp cool air and sunshine as well.
just been playing back the laps in my mind over and over on the drive home and i m sure ive found a couple more seconds! :ph34r: cant wait to go back.
Tony & Rob hope you had a good last session? Tony i wish i had seen those 5m flames, thats a classic.
Last session was good. Did a PB :D
Spun off though, thougt I'd be try and cool and try and keep in front of a pesky Rex for a few turns :P
lol, pipes need beads on the outside. Also, you should be able to get 1M lengths of silicon pipe off SAU silicon guys to replace the rubber poo that is on there atm. That should stop them blowing off.
I'm hoping someone has video of the flame!
was good to get out there. now i gotta keep going to track days to learn how to drive!
good to see you got some good laps in after the dramas tony!
Yeah the first morning was so frustrating, only 1 lap in 2 sessions and working furiously on the car to get in right for the next session :/
video of my fastest lap of the day.
pretty happywith the lines, was getting some bad understeer tho, think too much grip from rear. need semi's for front next.
got my PB just in time.
made it half way to shepp b4 the rear brakes gave up the ghost and went metal on metal
so need to fix them and a windscreen b4 HH.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
