  • Replies 68
Updated 18.1.12
Standard side mount cooler - 20
Apexi PowerFC to suit r33 gtst with hand controller (perfect condition) - 900
Xforce stainles r33 catback perfect condition with hiflow cat - 300
3inch dump and front pipes - 100
Hi flow cats - 80
3inch full exhaust with spare 2.5inch rear section to pass noise test - 350
Alloy radiator with thermo, 60mm - 150
Rb25det manual gearbox - 1200
20inch rims suit show spec skyline, black with chrome lip - 800
GT35r with hi mount stainless manifold, dump and front pipe with external gate - 1600
s1 engine loom - 150
s2 engine loom - 150
s2 coilpacks - 100
s1 ignitor module - 50
Coilpack loom - 50
Haltech e11v2 - 1100
z32 AFM - 150
Alternator - 50
Air con compressor - 50
Power steering pump - 50
Starter motor - 40
r33 GTR drivers seat - 400
rb25 shifter - 50
Walbro 255lph fuel pump - 80
Nismo 555cc injectors, cleaned and flow tested with receipts - 500
s2 factory turbo,complete with all lines and fittings - 180
Factory fuel rail with injectors - 70
Enkei rp01's - 700
Momo leather steering wheel - 40
RHF guard s1 (grey, white perfect condition) - 70
LHF guard s1 (black, red, white. perfect condition) - 50
Headlight (s1 LHF has some damage, ask for pics) - 50
Headlight (s1 LHF perfect) - 180
Headlight (s1 RHF perfect) - 180
Bootlid (s1 spoiler in black or white, great condition) - 20
Front shocks (standard but great condition complete with springs) - 20 each
Rear shocks (standard but great condition complete with springs) - 20 each
Standard r33 wheels (heaps in stock) - make offer
s1.5 steering wheel with airbag - 60
Steering wheel (s2 excellent condition) - 60
Airbag (s2 excellent condition) - 20
Dash facia (good condition) - 50
Gear surround (small tears) - 20
Gear surround (great condition, no ripped leather) - 50
Indiator stalk - 10
Wiper stalk - 10
Airbag control unit - 10
Wiper motor - 20
Steering column - 10
Taillights (grey, black, red, white) - 30 each
RB25det long motor - 900
Heater core - 40
Manual tailshaft - 50
Front upper control arms - 10 each
Castor rod LHF - 20
Castor rod RHF - 20
Lower control arm LHF - 50
Lower control arm RHF - 50
Castor rod brackets - 10 each
S2 AFM air flow meter pink label - 50
S1 AFM air flow meter green label - 50
Drivers seat (perfect condition no rips) - 40
Passenger seat (great condition) - 20
Rear seats (great condition s2) - 30
Dashboard - 40
Centre console - 20
Steering column lower trim - 20
Glovebox - 15
Drivers seatbelt - 40
Seatbelts - 20
Sunroof switch - 10
Interior map light - 20
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (tie rod end to tie rod end) - 40
Jack - 20
Interior parts - just ask, have heaps
Front subframe - 40
Gearbox mount with bracket - 30
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 350
Rear cradle - 20 each
Diff (lsd manual ratio) - 120
Front window glass, drivers and passengers - 10 each
Radiator/condensor fan x2 - 10
Radiator with hoses - 30
Manual conversion parts
Pedals - 40 each set
Clutch master cylinder - 30
Clutch metal hard lines - 20 each set
Brake Booster - 20
Brake master cylinder (non abs) - 40
Brake master cylinder (abs) - 50
Drivers window reg with motor - 70
Passenger window reg with motor - 40
Passenger door trim complete - 20 each
Drivers door trim (without window switch) - 20
Drivers window switch (8,11 and 12 pin in stock) - 120
Rear lower control arms - 10 each
Rear upper control arms - 10 each
Half shafts - 30 each
Drivers door skins (few different colours to choose from) - 20
Passenger door complete with glass and motor/reg (white, black, red) - 80
Intake manifold - 30
Space savers - 20 each
18 inch tyre kuhmo 95% tread - 30
19 inch tyres 245s michelin pilotsport 70% tread - 100 the pair
plenty more thats not listed just ask!
spunky munky yes I do have z32 for sale. please contact me on 0424999936.
RRP1 no green labels atm sorry.
Konflictr33 I had them until last night, $150. my number is 0424999936 if you're chasing anything, I'll reply a lot quicker than comments on here that I dont see for weeks.
  • 2 months later...
Updated 7.5.13
3inch full exhaust with spare 2.5inch rear section to pass noise test - 200
20inch rims suit show spec skyline, black with chrome lip - 600
s2 coilpacks - 100
Coilpack loom - 50
Alternator - 50
Starter motor - 40
rb25 shifter - 50
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
Heater core - 40
Castor rod LHF - 20
Castor rod RHF - 20
Dashboard - 40
Centre console - 20
Glovebox - 15
Seatbelts - 20
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Jack - 20
Front subframe - 40
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 370
Front window glass, drivers and passengers - 20 each
Radiator/condensor fan - 20
Clutch metal hard lines - 30 each set
Brake Booster - 20
Brake master cylinder (non abs) - 50
contact 0424999936
  • 3 months later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
