right i cant remember what its called for the life of me, but as soon as i remember ill let you know.
its a thread release spray similar to wd40 but a shit load more expensive. white can with a red lid and red writing, got it from bunnings right next to wd 40.
spray it on your lights for a few minutes, then give her a good old scrub, repeat until shiny!
if it fks your lights dont blame me. but mine look like new!
there you go 20 bucks 10 mins. all good.
https://www.sau.com.au/forums/topic/406646-magic-headlight-fix/
  • Replies 47
Posted Images
Hi mate,
That has wiped off the oxidation so it looks better = good. Can get similar results hand polishing with a cutting compound.
However, this process has also wiped off the UV protection. I'd suggest you reseal it before the oxidation comes back with a vengeance.
Good post.
no thats not the badger.
sorry for the vagueness of the post. i savagely cant remember what it was called as it went in the bin cos' it was empty.
how can you tell the uv protection came off? not being funny just asking. all that was on my rag was black sh*t.
Hi mate,
what can you use to reseal bloke?
Hello,
The final application will still need to have a UV inhibitor or UV resistant nanotechnology for the cloudiness to not return within 6 months.
Example:- Some polishes (perhaps Nu Finish?), sealants (Optiseal) and waxes (Malco Creme Wax)
Thought i'd just cut and paste it as Tez explains it better than me anyway.
Can find further info in here - http://www.skylinesaustralia.com/forums/topic/403833-cloudy-headlights-no-more/
If you do decide to go the extra step and clear coat them, dont use a standard clear. I have used 3M Heat Proof Clear on my 350Z and S15 headlights previously. After prep, I did numerous clear coats, wet sanded them down and buffed them hard with my DA polisher to make them extremely smooth and shiny. Its not a necessity, just depends how anal you are.
I havent done anything to my R34 lights yet, still tossing up whether to restore or replace.
thanks ill bear that in mind.
crc
that sounds right. i couldn't believe how well it cleaned them. it seems no there is a down side........
Thats okay mate, atleast its done a good job prepping them for the next step.
So what exactly is this CRC product, is it a lot better than Maguires plastx?
im not sure because i havent used the maguires.but its just a thread release spray similar to wd40 i suppose.
Meguiats Plastix is a 'specially formulated' plastic polish which removes light oxidation, chemical degradation, surface contamination, stains and light surface scratches from clear plastic surfaces. Favourable for headlights.
I smash it on there with a mothers powerball.
More info - http://www.meguiars.com.au/products/car-care/glass-clear-plastic-and-exterior-trim/plastx/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
