Hey Guys,
Just wondering what the normal oil and water temps those of you with R33 GTST's are getting, especially with a Front Mount Intercooler.
My oil is around the 80-90 degrees, and water is around the 85-95 degrees on normal daily driving. Freeway driving they are lower, oil at 75-85 and water 80-90 Just wondering what you are getting. Is over 100 bad for water (ie boiling)?
I'm a bit concerned that these temps are a little high. Both water and oil temp gauges are after market. The oil temp sensor replaces the sump plug, and the water temp sensor is in the pipe that goes to the top of the radiator which i think is the return pipe so i kind of expect it to be hotter than the 76 degrees the thermostat opens at.
Just thought i'd see what others are getting.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/40665-r33-gtst-oil-and-water-temps/
from my understanding coolant added to water makes the boiling point rise to somewhere like 110 - 122 degrees celcius. Prolly go even higher due to the fact its a pressurized system.
The oil i have heard turns to water basically at 140deg celcius b4 engine damage starts....
hope that helps :)
My Greddy's are the same as GiJor33's, and my exhaust normal driving 600' C, bringing the turbo on, 800' C, sticking it into it, 900' C max. Round town down as low as 300' C.
Oil pressure up to 6.5, but flickers with the revs heaps.
Sounds about the same as my oil temps.
This is what I've found;
Stock car (no FMIC, normal clutch fan) around 70 degrees,
Installed the FMIC, temps now around high 70's (~78),
Installed the thermo fan, temps up about another 5 degrees.
Sooo, mine sits at aroun 85 degrees with the FMIC and thermo fan.
J
  • 4 weeks later...
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
