Hey guys
Thinking of buying a new set of Varrsteon 2.2.1(te37 replicas) for my 34gt sometime this week.
Thinking of going 18 x 9.5 +22 front
and 18 x 9.5 +15 at the rears.
First question, would +12 at the rear look too agressive? as in, would they stick out of the guards too much? Would i have to roll guards?
Second question, what size tyres do you guys recommend?
Any help would be appreciated cos i'm pretty new to this stuff, thanks :)
https://www.sau.com.au/forums/topic/406793-tyre-size-and-offset-question/
yes you will probably have to roll the guards and yeah they will stick out a bit. will look wicked though. probably need camber arms in the rear to get good tyre wear/flush fit.
would go 235/40/18 tyres all round
Thanks for the reply mate :)
I have Tein SS coilys, the timid amount of camber that they create won't be enough for +12 ayee?
Should i go with +15's to be safe you reckon?
i dont mind rolling guards, but camber arms are a bit dear :(
^^^^ Not really because the rim isnt as wide as the rear.
Thanks for replying mate, i took the safe option and ordered +30 all round with 10.5's at the rear and 9.5's at the front.
I'll put up pictures when they are fitted :)
won't the front look more aggressive than the rear in that case?
No - 1 inch is 25.4mm, so there will be 13mm extra either side, and the difference in offset is only 8mm so the rears will stick out 5mm more than the fronts.
Hmm, 5mm isn't much at all ayee, it wont be noticeable enough :/
I wouldnt be too worried about looks - if it doesn't fit properly you will hate it regardless of how it looks. Not that i'm saying anything about fit, because I dont know.
  • 3 weeks later...
updates? keen to see pics fitted
I ordered 10.5's with 255 for the rear, 9.5's with 235's for the front. Still awaiting shipment, paid a month ago :(
I'll put up pictures as soon as they're fitted
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
