Hi Guys
New to the Forums and Skylines.
Was a Z32 owner a few years back until the GFC made my job redundant and money tight.
Just picked up a Perl white 2006 V35 Premium on Friday. (I'm in love with motoring again)
I'm buying the 19" rims off Mitch28 today so I'll have extremely clean 18" rims and rubber left over.
Does anyone know if they will fit my sister in-laws nissan tida?
I think they would make the Tida look a lot better.
Regards Fodder.
https://www.sau.com.au/forums/topic/406819-18-wheels/
Thanks for the reply and yes the Tiida only has 4 studs.
So I suppose I should put the 18" wheels up for sale.
Before I put them on ebay I'll offer them on the forum for a while.
What I've got in 18" rims from a 2006 V35 Skyline.
Front: 225/40 R18
Rear 245/40 R18
Rims in fantastic condition - no gutter rash with lock nuts.
Near new rubber: Federal Rotalla F107's.
I have seen online from $700 to $1900 - various condition and rubber
$900 negotiable
http://www.mediafire.com/?cdxhrjvdk2xliox
http://www.mediafire.com/?uqng4wqthal69rd
http://www.mediafire.com/?6hu1523glhplin2
http://www.mediafire.com/?hu55xv25mcswt43
http://www.mediafire.com/?13pv9xi11jcpdcu
https://www.sau.com.au/forums/topic/406819-18-wheels/#findComment-6493850
Front: 225/40 R18
Rear 245/40 R18
$900 negotiable
Hey fodder,
where you located?
https://www.sau.com.au/forums/topic/406819-18-wheels/#findComment-6496156
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
