2001 s15 Silvia For Sale - 149,000, Extensively modified meticulously looked after.
MODIFICATIONS:
ENGINE
Custom 2871r .64 450HP turbo,
38mm external Tial gate welded with Tial 18psi spring combination onto stock cast manifold and coated with screamer pipe
HKS 256/264 10.5m lift camshafts with rocker arm stoppers
EXHAUST/INTAKE/INTERCOOLING
MM 3" Bellmouth dumppipe
XFORCE 3" Exhaust
GREDDY LM-Spec Intercooler
GREDDY Hotpipe
ASI Aluminium 52mm radiator
3A Racing pod filter (voted best for cooling & filtering)
FUEL & ELECTRONICS
Apexi PowerFC D-Jetro with FC & Commander
Apexi boost gauge
Nismo fuel pump
Nismo 740cc injectors
Sard FPR with Sard gauge
Phillips Crystal vision lightbulbs (had HID's but got defected, these bulbs are $150 a pair)
Cusco oil catch can
MARS L.E.D tail-lights
Full pioneer sound system with custom fiberglass sub box molded to side of boot to maximize boot space
SUSPENSION DRIVELINE/BRAKING
RDA front & rear slotted rotors with QFM race pads
D-Project Castor rods and camber arms
Xtreme Heavyduty organic clutch and lightened flywheel package
Whiteline F/R Swaybars
Rota Grid 18" 9.5 +20 all round wheels with brand new tyres
BC BR "GOLD TOP" coilovers lowered to optimum height
EXTERIOR/INTERIOR MISC PARTS
genuine aero rear pods and side skirts spray matched to car
DC2 Integra front lip moulded to front of car
Nismo radiator cap
Nismo oil cap
Carbon fibre slam panel (radiator panel)
Carbon fibre centre console
Carbon mirror covers
Assorted stainless dress up engine parts
Nardi style steering wheel with boss kit
Yashio factory gearknob, gearboot and drift button
There is probably a lot more to add to the list but I am tired and can't think of it at this stage, all parts have been selectively chosen to the car by me and professionally installed.
This car has been my pride and joy and I still have the original receipts from when it was bought inside the Nissan leather service pack manual. The car has never been thrashed as it's tune only recently got completed a month ago. It makes 230rwkw on a VERY safe tune from an experienced tuner who deals with machinery worth millions of dollars.
The car will be missed but I am at the next stage of my life. It will be missed and hopefully sells quickly. I take pride in my car and the list of modifications along with it's condition will sell itself - I am 25 years of age and not 17 with an edge wanting to lose my licence. Serious buyers only, please no time wasters
SERVICED EVERY 5000km WITH TOPSHELF OILS AND LUBRICANTS
AUSTRALIAN DELIVERED FOR CHEAPER INSURANCE
METICULOUSLY LOOKED AFTER AS THE TUNE WAS ONLY JUST FINISHED A MONTH AGO AND WAS KEPT ESSENTIALLY STOCK
ORIGINAL PURCHASE RECEIPTS
  • 4 months later...
Car has been changed a little since deciding to keep,
Now sporting Drift Blade interior black seats with POWERAILS rails.
HIGHMOUNT TD06SL2-20G 10cm Highmount turbo
FORCED MOTORWORK custom steam pipe manifold with 44mm Tial External wastegate
250kw on a VERY safe tune, Only finished less than a month ago and back up for sale again. Need house deposit by March.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
