4 of these wheels, suit skyline. may fit others.
17x8 approx +26 225 fronts with legal good bridgestone potenza RE01 adrenalin tyres.
17x9 approx +28 235 rear with dunlop tyres on indicators.
Unknown brand
Fresh paint! One has small flake where centre cap goes
500 firm come get em Ararat, VIC 3377 0423 393 521 message me I cant take calls. not interested in postage.
https://www.sau.com.au/forums/topic/407265-17-wheels/
  • 4 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
