  • Replies 49
Yes very true it did! But the vehicle was last registered with a rd28 which is the original motor.
Yes ive read up abit on VCT? Not needed you reckon? Because that makes things simpler again. Because then I won't have to tap into the oil sender ect.
You've been very helpful! Thankyou
If I dont want vct do I just weld or grub screw the oil gallery in the head and don't worry about tapping into the pressure sender? Also if I block off the vct i don't need to add oil restrictors to the head?
Sorry about all the questions im trying to read up and search things as much as possible, I've got the head and block at home so I'm gonna start getting it prepared
Edited by zac320
Quite the opposite. I kill people to get VCT. You want it
I'm in Vic if the laws are different to other states? Anyway Im buying a new nearly complete engine. The heads a series 2 and I'm just wondering will my s1 coils fit? I have the igniter and everything else just wondering as they are brand new OEM ones.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
