It's a real nice shock when you first squat in weighlifting shoes if you've been doing it in runners.
I used to squat barefoot until a month ago.
Got some squat shoes, they are amazing. Suit my needs perfectly and I'm not sure why I didn't purchase any sooner.
I was using the DO-WINS for a long time.
But have turned to flat shoes like chucks in the last 6 months or so.
I have 2 pairs of chucks and an older pair of Levis flat shoes of all things.... and these are the ones I lift in.
it just feels like a better fit.
For sale - one pair of Do-Wins lol
I have a few guys with the Adidas Adipower in here. Great shoe as the heel isnt as high as others
Keep them Tolga, Nina and Max have gone back and forth so often, but both are in flats now
The raised heel takes a lot of stress off my hamstrings, activating quads more, which is the main factor for me.
I used barefoot shoes before hand, 4mm flat sole, thought they were solid platform before the adipowers.
I've got no idea how unstable people in runners must feel.
Edited by jangles
The guy in the ab shot is Martin, he has dropped from 86kg to 79kg so he can lift in the 80kg class at ProRawFive, he needs the money
His best lifts this week were 220kg squat, 147.5kg paused bench and 281kg deadlift
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
