In the raw uncut one I simply let the camera roll without stopping, nothing planned or premeditated. A few have asked what goes on between sets as I only post up max attempt lifts usually.
Our new channel wont feature any 1RM stuff, I'll keep that on PTC Frankston
It will be a fun day, Rebecca is competing, she needs around 300kg at around 58kg to qualify for ProRawFive
I think she will go around 110/62.5/140 - 312.5kg. She is 57kg at the moment
She is still a junior, only 23 years old. She will do States, Nats, Worlds and ProRawFive this year
She wants to give powerlifting a decent crack this year
yep 180 at ProRaw... no wraps or belt but in a pair of Do Wins
I was feeling strong yesterday, was tempted to throw on some more weight and go for a single rep PR but will wait a week or two before I start doing singles
training by yourself is hard... training with strong people around gives you extra motivation... I'm definitely making better progress switching my training to PTC... that and I've pretty much been on holiday since christmas lol
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
