2013 GPC Vic States
WOMEN
48kg class
1. Melissa Knight - 47.7kg - 85/47.5/110 - 242.5kg
60kg class
1. Rebecca Gleich - 57.8kg - 120/67.5/150 - 337.5kg
2. Sussy Kollen - 57.8kg -110/72.5/120 - 302.5kg
3. Vicki Jewson - 57.7kg - 90/57.5/130 - 277.5kg
67.5kg class
1. Heidi Stewart - 60.6kg - 110/70/150 - 330kg
2. Megan Reily - 65.4kg - 100/BMB/130 - BMB
75kg class
1. Jay Jama - 71.0kg - 60/30/95 - 185kg
82.5kg class
1. Emma Bortolotto - 81.9kg - 130/67.5/140 - 337.5kg
MEN
56kg class
1. Marlon John - 54.8kg - 115/80/120 - 315kg
67.5kg class
1. Jesse Markopoulos - 66.8kg - 160/100/190 - 450kg
2. Luke Bender - 66.0kg - 110/100/200 - 410kg
75kg class
1. Emad Nayef - 74.7kg - 235/115/255 - 605kg
2. Robbie Tissera - 73.1kg - 227.5/120/220 - 567.5kg
3. Ivan Ho - 70.7kg - 165/120/170 - 455kg
4. Dim Papaconstantinou - 70.5kg - 145/100/185 - 430kg
5. Daniel Distefano -69.5kg - 125/100/160 - 385kg
82.5kg class
1. Martin Nguyen - 80.9kg - 252.5/157.5/275 - 685kg
2. Eddie Dargham - 81.2kg - 185/105/250 - 540kg
3.Chris Van Gunst - 78.3kg - 150/125/235 - 510kg
4. Jordan Zollo - 82.4kg - 150/130/200 - 480kg
5. Sam Boyce - 81.3kg - 140/112.5/185 - 437.5kg
6. Dimitri Jayaratne - 76.7kg - 135/57.5/175 - 367.5kg
7. Adrian Zwaan - 81.9kg - 95/80/160 - 335kg
8. Krit Barnett - 82.0kg - 130/105/65 - 300kg
90kg class
1. Max Markopoulos - 89.8kg - 260/155/250 - 665kg
2. Adam Lam - 89.3kg - 240/140/260 - 640kg
3. Erros Chiodo - 88.0kg - 215/125/275 - 615kg
4. Nick Edlin - 88.8kg - 210/132.5/240 - 582.5kg
5. Keng Tan - 89.7kg - 215/142.5/220 - 577.5kg
6. Conor Zyskowski - 87.0kg - 230/110/230 - 570kg
7. Stelian Tchapkanski - 89.9kg - 180/150/215 - 545kg
8. Ethan Perera - 87.3kg - 130/80/150 - 360kg
100kg class
1. James Jenai - 94.5kg - 245/175/250 - 670kg (180kg 4th BP)
2. James Visciglio - 97.9kg - 195/135/272.5 - 602.5kg
3. Nick Haralambopoulos - 97.6kg - 185/120/250 - 555kg
4. Wayne Kollen - 99.8kg - 200/130/225 - 555kg
5. Josh Rayson - 96.9kg - 185/120/220 - 525kg
6. Kris Baldry - 99.7kg - 200/105/205/510kg
7. Ronnie Chau - 94.6kg - 170/100/242.5 - 512.5kg
8. Ross Katsambis - 97.7kg - 170/105/215 - 490kg
9. Jake Clinch - 95.1kg - 70/140/75 - 285kg
10 . John Nichols - 93.6kg - 80/75/75 - 230kg
11. Aaron Scarborough - 96.6kg - 80/80/65 - 225kg
110kg class
1. Daniel America - 104.3kg - 230/140/260 - 625kg
2. Nick Rankin - 102.3kg - 200/140/240 - 580kg
3. Will Grainger - 105.8kg - 215/125/230 - 570kg
4. Duke Catherine - 108.2kg - 135/105/190 - 430kg
5. Jeremy Buchanek - 101.1kg - 80/75/75 - 230kg
6. Gregg Gordon - 108.5kg - 80/75/75 - 230kg
125kg class
1. Zoran Jankovski - 114.3kg - 250/145/292.5 - 687.5kg
2. Joe Zollo - 119.1kg - 220/120/240 - 580kg
3. Alan Kissick - 116.8kg - 165/105/215 - 485kg
4. James Thompson - 116.0kg - 110/85/175 - 370kg
140kg class
1. Spiros Markopoulos - 128.0kg - 70/152.5/75 - 297.5kg
SHW
1. Jack Pollard - 148.1kg - 280/170/280 - 730kg
EQUIPPED MEN
100kg class
1. Barry Murray - 97.1kg - 200/160/200 - 560kg
2. Brendan Hains - 95.1kg - 270/BMB/260 - BMB
BENCH ONLY
WOMEN
82.5kg class Equipped
1. Emma Bortolotto - 81.9kg - 90kg
MEN
100kg class
1. Laird Ross - 93.9kg - 180kg
2. Alen Pezerovic - 93.9kg - 130kg
Stoked, got my 102.5kg x3 bench out last night!!!
Week 7 here I come.
Tried doing some paused reps on 90kg and wow that makes it about fifty times harder. No way would I get 102.5kg out without utilizing the stretch-shorten cycle.
the pause does get easier the more you practice it... just have to concentrate on keeping tension
That's what I've found when I've dicked around with the pause. You habitually allow too many muscles to relax when you pause, as your mind wants to use it as a chance to rest....when in reality you want the exact opposite! Keep those muscles tensioned haha
SS as in starting strength?
SS is 3 sets of 5 reps for working sets for sq, bench, OH press
Deads is 1 set of 5 reps
Power cleans are 5 sets of 3 reps.
There are no 5 working sets apart from the power cleans.
and warms ups is a personal thing... if I only did 2 warm up sets and got straight in to the work sets, I'd break more frequently than I do now.
SS as in starting strength by Mehdi
think the program has changed slightly but I could very well be wrong.
Workout A:
Squat
Bench
Barbell Rows (I don't do these, I do seated cable. Reason is I get heaps of pain in my wrist joints from it)
Workout B:
Squat
Overhead Press
Deadlifts
Straight from his book that he sends to everyone:
"You'll do 5 sets of 5 reps (5x5) with the same weight on every exercise after you've done
your warm-up sets. There's 1 exception, Deadlifts, where you'll only do 1 set of 5. Here's
why: 5x5 or even 3x5 Deadlifts would mess with your recovery and cause stalling because
you're already doing 5x5 Squats 3x/week. I urge you to stick with 1x5 Deadlifts."
"Never jump straight into your work weight, warm-up first. As an example, let's say your
work weight for the Squat is 135lbs. Then here's how your training would look like...
• 2×5 45lbs => 2 sets of 5 reps with the empty Olympic bar
• 3 x 90lbs => 1 set of 3 reps with the 45lbs bar + 22.5lbs/side
• 5 x 135lbs => first set of 5 reps with your work weight
• 5 x 135lbs => 2nd set of 5 reps with your work weight
• 5 x 135lbs => 3rd set of 5 reps with your work weight
• 5 x 135lbs => 4th set of 5 reps with your work weight
• 5 x 135lbs => 5th and final set of 5 reps with your work weight"
"Notice that on the Deadlift you only do 1 set of 5 reps, not 5x5 or 3x5 because that could
cause stalling when combined with 5x5 Squatting 3x/week. So let's say your work weight
on the Deadlift is 225lbs, here's then how it would look like:
• 5x 135lbs => 1 set of 5 reps, 1st warm-up set
• 5x 175lbs => 1 set of 5 reps, 2nd warm-up set
• 5x 225lbs => 5 reps with 225lbs, your work set"
No mention of power cleans
If you want to read the entire book that he sends
there it is.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
