2013 GPC Vic States
WOMEN
48kg class
1. Melissa Knight - 47.7kg - 85/47.5/110 - 242.5kg
60kg class
1. Rebecca Gleich - 57.8kg - 120/67.5/150 - 337.5kg
2. Sussy Kollen - 57.8kg -110/72.5/120 - 302.5kg
3. Vicki Jewson - 57.7kg - 90/57.5/130 - 277.5kg
67.5kg class
1. Heidi Stewart - 60.6kg - 110/70/150 - 330kg
2. Megan Reily - 65.4kg - 100/BMB/130 - BMB
75kg class
1. Jay Jama - 71.0kg - 60/30/95 - 185kg
82.5kg class
1. Emma Bortolotto - 81.9kg - 130/67.5/140 - 337.5kg
MEN
56kg class
1. Marlon John - 54.8kg - 115/80/120 - 315kg
67.5kg class
1. Jesse Markopoulos - 66.8kg - 160/100/190 - 450kg
2. Luke Bender - 66.0kg - 110/100/200 - 410kg
75kg class
1. Emad Nayef - 74.7kg - 235/115/255 - 605kg
2. Robbie Tissera - 73.1kg - 227.5/120/220 - 567.5kg
3. Ivan Ho - 70.7kg - 165/120/170 - 455kg
4. Dim Papaconstantinou - 70.5kg - 145/100/185 - 430kg
5. Daniel Distefano -69.5kg - 125/100/160 - 385kg
82.5kg class
1. Martin Nguyen - 80.9kg - 252.5/157.5/275 - 685kg
2. Eddie Dargham - 81.2kg - 185/105/250 - 540kg
3.Chris Van Gunst - 78.3kg - 150/125/235 - 510kg
4. Jordan Zollo - 82.4kg - 150/130/200 - 480kg
5. Sam Boyce - 81.3kg - 140/112.5/185 - 437.5kg
6. Dimitri Jayaratne - 76.7kg - 135/57.5/175 - 367.5kg
7. Adrian Zwaan - 81.9kg - 95/80/160 - 335kg
8. Krit Barnett - 82.0kg - 130/105/65 - 300kg
90kg class
1. Max Markopoulos - 89.8kg - 260/155/250 - 665kg
2. Adam Lam - 89.3kg - 240/140/260 - 640kg
3. Erros Chiodo - 88.0kg - 215/125/275 - 615kg
4. Nick Edlin - 88.8kg - 210/132.5/240 - 582.5kg
5. Keng Tan - 89.7kg - 215/142.5/220 - 577.5kg
6. Conor Zyskowski - 87.0kg - 230/110/230 - 570kg
7. Stelian Tchapkanski - 89.9kg - 180/150/215 - 545kg
8. Ethan Perera - 87.3kg - 130/80/150 - 360kg
100kg class
1. James Jenai - 94.5kg - 245/175/250 - 670kg (180kg 4th BP)
2. James Visciglio - 97.9kg - 195/135/272.5 - 602.5kg
3. Nick Haralambopoulos - 97.6kg - 185/120/250 - 555kg
4. Wayne Kollen - 99.8kg - 200/130/225 - 555kg
5. Josh Rayson - 96.9kg - 185/120/220 - 525kg
6. Kris Baldry - 99.7kg - 200/105/205/510kg
7. Ronnie Chau - 94.6kg - 170/100/242.5 - 512.5kg
8. Ross Katsambis - 97.7kg - 170/105/215 - 490kg
9. Jake Clinch - 95.1kg - 70/140/75 - 285kg
10 . John Nichols - 93.6kg - 80/75/75 - 230kg
11. Aaron Scarborough - 96.6kg - 80/80/65 - 225kg
110kg class
1. Daniel America - 104.3kg - 230/140/260 - 625kg
2. Nick Rankin - 102.3kg - 200/140/240 - 580kg
3. Will Grainger - 105.8kg - 215/125/230 - 570kg
4. Duke Catherine - 108.2kg - 135/105/190 - 430kg
5. Jeremy Buchanek - 101.1kg - 80/75/75 - 230kg
6. Gregg Gordon - 108.5kg - 80/75/75 - 230kg
125kg class
1. Zoran Jankovski - 114.3kg - 250/145/292.5 - 687.5kg
2. Joe Zollo - 119.1kg - 220/120/240 - 580kg
3. Alan Kissick - 116.8kg - 165/105/215 - 485kg
4. James Thompson - 116.0kg - 110/85/175 - 370kg
140kg class
1. Spiros Markopoulos - 128.0kg - 70/152.5/75 - 297.5kg
SHW
1. Jack Pollard - 148.1kg - 280/170/280 - 730kg
EQUIPPED MEN
100kg class
1. Barry Murray - 97.1kg - 200/160/200 - 560kg
2. Brendan Hains - 95.1kg - 270/BMB/260 - BMB
BENCH ONLY
WOMEN
82.5kg class Equipped
1. Emma Bortolotto - 81.9kg - 90kg
MEN
100kg class
1. Laird Ross - 93.9kg - 180kg
2. Alen Pezerovic - 93.9kg - 130kg
Stoked, got my 102.5kg x3 bench out last night!!!
Week 7 here I come.
Tried doing some paused reps on 90kg and wow that makes it about fifty times harder. No way would I get 102.5kg out without utilizing the stretch-shorten cycle.
the pause does get easier the more you practice it... just have to concentrate on keeping tension
That's what I've found when I've dicked around with the pause. You habitually allow too many muscles to relax when you pause, as your mind wants to use it as a chance to rest....when in reality you want the exact opposite! Keep those muscles tensioned haha
SS as in starting strength?
SS is 3 sets of 5 reps for working sets for sq, bench, OH press
Deads is 1 set of 5 reps
Power cleans are 5 sets of 3 reps.
There are no 5 working sets apart from the power cleans.
and warms ups is a personal thing... if I only did 2 warm up sets and got straight in to the work sets, I'd break more frequently than I do now.
SS as in starting strength by Mehdi
think the program has changed slightly but I could very well be wrong.
Workout A:
Squat
Bench
Barbell Rows (I don't do these, I do seated cable. Reason is I get heaps of pain in my wrist joints from it)
Workout B:
Squat
Overhead Press
Deadlifts
Straight from his book that he sends to everyone:
"You'll do 5 sets of 5 reps (5x5) with the same weight on every exercise after you've done
your warm-up sets. There's 1 exception, Deadlifts, where you'll only do 1 set of 5. Here's
why: 5x5 or even 3x5 Deadlifts would mess with your recovery and cause stalling because
you're already doing 5x5 Squats 3x/week. I urge you to stick with 1x5 Deadlifts."
"Never jump straight into your work weight, warm-up first. As an example, let's say your
work weight for the Squat is 135lbs. Then here's how your training would look like...
• 2×5 45lbs => 2 sets of 5 reps with the empty Olympic bar
• 3 x 90lbs => 1 set of 3 reps with the 45lbs bar + 22.5lbs/side
• 5 x 135lbs => first set of 5 reps with your work weight
• 5 x 135lbs => 2nd set of 5 reps with your work weight
• 5 x 135lbs => 3rd set of 5 reps with your work weight
• 5 x 135lbs => 4th set of 5 reps with your work weight
• 5 x 135lbs => 5th and final set of 5 reps with your work weight"
"Notice that on the Deadlift you only do 1 set of 5 reps, not 5x5 or 3x5 because that could
cause stalling when combined with 5x5 Squatting 3x/week. So let's say your work weight
on the Deadlift is 225lbs, here's then how it would look like:
• 5x 135lbs => 1 set of 5 reps, 1st warm-up set
• 5x 175lbs => 1 set of 5 reps, 2nd warm-up set
• 5x 225lbs => 5 reps with 225lbs, your work set"
No mention of power cleans
If you want to read the entire book that he sends
there it is.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
