I was going great til I got sick and when I finished week 8 with the 110kg bench it felt like I had more in me.
I think I'll give it one more week and if I can't get it out next week ill start all over again on the 125kg bench program seeing as my 1rm has gone up
We had our GPC Nats Qualifier on Sunday. After getting 60 lifters to our States, we had a heap more who missed out and therefore not qualified for Nats, so we held the Qualifier and got another 23 lifters. We may have 100 lifters at States in 2014.
Edited by markos
We had our GPC Nats Qualifier on Sunday. After getting 60 lifters to our States, we had a heap more who missed out and therefore not qualified for Nats, so we held the Qualifier and got another 23 lifters. We may have 100 lifters at States in 2014.Here are the results from Sunday
WOMEN
52kg class
Yvonne Wagstaff - 50.5kg - 60/40/102.5 - 202.5kg
56kg class
Sharnee Griffiths - 54.6kg - 82.5/50/105 - 237.5kg
Sharon Wilkins - 54.1kg - 65/35/120 - 220kg
67.5kg class
Nina Markopoulos - 61kg - 115/70/130 -315kg (72.5kg 4th bench)
Ariel Symon - 63.6kg - 90/47.5/100 - 237.5kg
Steph Finnin - 66kg - 75/37.5/100 - 212.5kg
75kg class
Shandelle Ross - 73kg - 75/55/120 - 250kg
MEN
67.5kg class
Aris Juico - 66.9kg - 165/112.5/195 - 472.5kg
75kg class
Allen Ozdil - 73.9kg - BMB/112.5/207.5 - BMB
82.5kg class
Albert Ozdil - 81.5kg - 212.5/132.5/230 - 575kg
Eddy Dargham - 82.5kg - 190/110/245 - 545kg
Sam Nayef - 81.6kg - 185/110/210 - 505kg
Andrew Johnson - 77.4kg - 155/85/205 - 445kg
Daniel Patience - 80.6kg - 150/90/170 - 410kg
90kg class
Dylan Hart - 89.2kg - 195/125/250 - 570kg
Rowan Pratt - 86.8kg - 110/95/182.5 - 387.5kg
100kg class
Jake Clinch - 99.6kg - 170/150/225 - 545kg
Fernando Serra - 98.5kg - 125/62.5/145 - 332.5kg
Brent Cosnett - 97.1kg - 70/65/65 - 200kg
125kg class
Michael Read - 120.9kg - 190/132.5/215 - 537.5kg
140kg class
Mike Vrljic - 132.9kg - 100/na/na - BMB
SHW class
Matthew Stockdale - 146.1kg - 150/85/205 - 440kg
BENCH ONLY
Fiona Morris - 63.4kg - 67.5kg bench
Mike Vrljic is H Bomb, the 2013 Australia's Strongest Man. He just performed a token squat to qualify.
Fixed up a bit of the formatting for you Markos, stupid SAU is broked lol
Just completed week 10 of the 165kg deads program, got 160kg out. Now just gotta step it up next week and pull 165.
The only part of PPP that has stalled for me is bench and feel like that might be partly technique related. By no means am I saying my squat or dead form is good, just not as big of a hinderance yet...
good work... you'll make that 165kg... just have to get a bit fired up, grab it and rip the shit out of it!
bench is tricky... it definitely doesn't progress as quickly as the other lifts... I'm still learning the technique
Its a skill you need to learn
Firing all your fast twitch fibres for a max effort is a skill
I have some lifters that need to learn to do 5 reps
Once your a complete lifter, you'll progress much faster
Zoran was awesome at singles, crap on 10's
Now he's much better, and much stronger for it
Got out the 165kg dead this morning! Didn't think it was going after I did the 157.5 before it and it felt tough but I got it up!
What happens when you finish that PPP program? Do you just pick a different weight and start again the next week or what?
Edited by Mitcho_7
did you read the PPP program?
It says do anything you like, just not that exercise
The cycles are 11 weeks long. You should get through 4 cycles per year. That’s 44 weeks,
which leaves 8 weeks. At the end of each cycle, I want you to do whatever you like, no
structure.
You can rest, do bodybuilding, train the whole body, curls for 2 weeks, it doesn’t matter. It
will allow you to freshen up your mind and body, this is very important. Go and jog for all I
care, you’ve earned it.
Edited by jangles
    • Definitely a good “future upgrade” option if you plan on keeping the car and dialing it in even further.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
