Daniel America tore his pec in January, the tear was 3cm wide, 3cm deep and 3cm long.
He has reverted to reverse grip on his benching, and today benched 170kg. His PB was 167.5kg, the set before his pec tore in January.
He will bench over 180kg on September 8th at Melbourne Cup.
We have a comp at PTc on Sunday the 8th, GPC Melbourne Cup.
I have 3 new clients competing at their first sanctioned meet, Jason, Alex and Arthur.
This morning Jason squatted 200kg@75kg on his last heavy session before the meet
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
