1995 180SX ready to drift!
Engine:
RB25DET Series 2 approx 100xxxk's
Brand new Garret GTX3076 .82 rear
Teflon Braided lines everywhere
6 Boost Manifold
Tial 44mm Wastegate with screamer
Greddy Style Plenum
JECS 1000cc Injectors
Q45 Throttle Body
Front Mount Intercooler Core / Z32 AFM
Mishimoto Ally Rad
Massive K&N Pod
Custom 3" Exhaust to 3.5" Tips
Custom Tubs and Tube Front End.
Full custom rewire to switch panel and fuse box under dash.
Custom catch can setup
Car makes 260kw on 15psi, Its safe and can get more power out of it but it has no troubles spinning the 11's in 3rd all day.
Exterior:
Wed Kranze Lxz's in 18x9.5 -14 and 18x11 -29 with brand new 215/40 federal 595's and 235/40 new no name brand
40mm DMAX Front Fenders
50mm Wise Square Rear Overfenders
Viva Garage BN Body Kit (seen better days but still works)
Viva Garage Roof Spoiler
Bonnet Vent
Type X Tailights
Interior:
Apexi Power FC with Hard Controller
Apexi RSM
Cusco 6 Point Roll Cage
2 Foot Hydralic Handbrake
S15 Dash
Red Bride Zeta 2 for drivers and a red bride ergo for passagers
Saber Boost, Oil Temp, Oil Press, Water Temp guages
Battery Relocate Behind Passenger Seat
Driver and Passenger Harnesses
Driveline:
Extreme Drift Clutch/Flywheel Combo
RB25 Gearbox
1 Peice Steel Driveshaft
4.3 ratio 2 way diff
SP garage solid subframe mounts
Suspension:
S14 rear brakes and hubs
z32 Front Brakes
Megan Racing Track Series Coilovers 12kg/10kg
Megan Racing Tie Rods & Ends
Megan Racing Toe Arms
Megan Racing Rear Camber Arms
Megan Racing Tension Rods
Megan Racing Traction Rods
NP Wonder knuckle kit, modded knuckles, longer and strenghted LCA's, BA falcon tie rods and ends, thread adapters with built in spacers. It means big lock setup. Same setup Nigel and the boys run on there cars.
JJR tension rods
Car is NOT registered but has no defects or epa on it so it can be with a blue slip. I was thinking about rego it myself but would probley on last 5 mins on the road before being red stickered. Everything on the car was vought brand new and has only seen 4 track days in total, all the suspension gear hasn't seen more then 600km's on them. I really like this car, the way it looks and goes on the track is incredable but theres no point in me having a track car when i don't have a tow car or trailer plus i'm walking to work because i haven't got a daily which i'm over.
Looking at getting a jzx90/100 or a r32 gtr so i would be keen on swaps even cash your way if its got good parts on it. Even tho saying that i would swap for something jap and rwd with abit of power so don't be afaid to offer. No commo's or ford thanks!!!
Price is $17,000 with everything
Can do it for 15,000 without wheels but i reckon rims make the car.
Contact number is 0424580115, pm me or give me an email at [email protected]
Cheers guys
Stephen
post-74647-0-43751700-1345547374_thumb.jpgpost-74647-0-53812900-1345547427_thumb.jpgpost-74647-0-75925200-1345547404_thumb.jpg
Edited by bams_180
https://www.sau.com.au/forums/topic/407518-setup-drift-180sx-low-wide-loud/
cheers fella's, its a great car to own and drive but can't handle this NSW business of driving the car once in 4 months on a proper track and not a skid pan.
Ain't that the truth! It's beyond a joke now.
GLWS mate, seen it in person a few times ... thing is off the chain!
This car is awesome have seen so many pics of
It recently and spent a lot of time drooling
Over it haha good luck with the sale
Mate if I had the cash I would be knocking on your door right now
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
