I am very curious on peoples opinions on what they consider is fast. my car was put on the dyno last week and was making 222kw at the wheels at 10psi boost. I have standard injectors so I cant go higher than that.
problem is though, the car feels laggy as hell, and seems slower compared to the standard turbo I had previously on it. I am just not impressed. why? :(
anyone happy with 220kw at wheels?
https://www.sau.com.au/forums/topic/407706-is-220kw-at-the-wheels-powerful/
Specs and dyno sheet needed!
Ill get on that soon man. but whats your opinion? shouldn't 220kw at the wheels be brutal?
because my car aint brutal unless I boost from 1st gear. anything higher than that takes forever for the damn turbo to kick in. hits hard when it does though, but damn it takes forever. not happy with the performance of the r33 gtst :(
220kw is nothing to get excited about BUT you did say it was at 10psi which is probably not even waking your turbo up, hence your not happy! If you have a bigger turbo thats what happens!
what turbo do you have?
when are you hitting boost by?
is anyone happy with 220 atw? maybe.. its personal preference. get some bigger injectors/pumps/reg and wind the bitch up
high flow garret turbo. hitting boost pretty late man...
edit: ok my tuner just called, he said he wasn't looking to get power out of the turbo until I had run in my new engine. he said it was a conservetive tune, Ill be taking it back to him on monday for him to improve the timing on the ecu or something. apparently thats why its not accelerating hard... :unsure:
Edited by BOOSTBIG
power coming on too late means slow car, eg dyno queen.
If you did fuel injectors, airflowmeter, you could then use more boost and wake it up...
Otherwise maybe the turbo is too big?
I drove an R33 GTS-t years ago and it had high flowed turbo, front mount, injectors, tune, exhaust running 18psi, it was bloody good!!! Felt like 250-270RWKW
Yea man, with the amount of mods done to my car you would think it would be pulling hard!
lets see what happens monday. if not ill be selling it and buying a gtr lol
anyone want a fully rebuilt r33 gtst? lol
On the flipside of that Sean i had a high flow on my car making 250kw and it was pretty disappointing, so some good and some bad i guess.
True. The one I drove was right on the limit, as it was knocking on high boost! We are talking like over 8 years ago haha..
A laggy turbo that has a useful powerband of say, 5500RPM through to 7000RPM will feel fast (ramps up onto boost quickly) but will actually be slow compared to a car with a more useful powerband.
Big difference between "feeling fast" and actually "being fast" and it's all in the powerband.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
