Hey guys, just got my new daily on the road (R32 4 Door). But my heater doesn't work. Like, literally doesn't work. I took the heater door servo off and moved the arm by hand to what would be full heat. Nothing. Cold as ice. And yes the heater core is plumbed up.
Potential causes I can think of:
Heater core blocked
Massive air lock
Heater core pipes around the wrong way
I will investigate further tomorrow, but just thought I would see if anyone else has had the same thing, because its rather weird.
Chances are the heater core is gone.
Check the passenger side carpet and see if its wet at all.
Have you done anything that could have caused it?
You said the hoses could be around the wrong way so have you changed them recently to cause this or it just stopped working?
There is no moisture in the car, that I've found.
And yeah, I have just put a new motor in, so the hoses were disconnected/re-connected.
I'm trying to remember if it worked before, but my memory is failing me.
The heater should have been burped of air , engine in heater on full hot to be sure the core was passing without air traps which fry heads
Did you back flush the system ? Should have before new engine ?
The heater mixture solenoid working on the r34 its below the master cyl , fuel filter area not sure on 32's? , yank both hoses off core by turbo dump and try a garden hose with screw type ( cheapo) sprayer , try to put heater core in hot position by hand and run water into it on low / med pressure and expect the other hole to flood out crap or if its blocked nothing will pass , reverse and try the backwards way ? Anything ?
Once done reflush system and refill heater on hot
And fan on low, drain air out of bleeds a few times
After hot and cool cycle , overflow will be sucked in a bit more then normal for a few days then settle full
If you want to flush the whole system you need to use specific hoses , let me know
Edited by Carbon 34
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
