Parting out an accident damaged 1995 33 gtr with some aftermarket parts.
No engine, brakes or front seats. Front end damage so no front body panels.
Parts are located in Ipswich qld and I can be contacted via ph. 0413863207 or pm on this forum.
Pickup is available and payment is by cash or postal money order. I do NOT do bank transfer or paypal so please dont ask.
Condition of parts is as described.
Pics.
Aragosta coilovers. these are top shelf coilovers, condition is very good with just cosmetic marks from road blast. No leaks or knocks......$1750.00
post-35087-0-55797600-1345957291_thumb.jpg33gtr gearbox complete with shifter and cross member. Good working condition...$650
Nismo white face dash cluster and triple centre guages, dash cluster is mint with low kays, centre guage are in excellent condition with just a broken corner on a mounting tab. has zero effect on the guage and can not be seen when installed. $650.00 the pair
Genuine C's short shifter with heavy throw shift knob, excellent condition...$175.00
Walbro in tank fuel pump wired and ready to clip straight in, perfect condition...$150.00
Genuine Nismo clear indicators with bulbs. perfect condition....$40.00 ther pair
post-35087-0-75649700-1345957487_thumb.jpgWhiteline front sway bar with adjustable links in excellent condition...$200.00
Genuine nissan gtr rear strut brace in excellent condition with mounting brackets..$100.00
Nismo brake lines for gtr, front and rear in very good condition...$150.00
HKS priest stainless exhaust with cat and will throw in front pipes, system is in great condition with just road wear $450.00
Genuine 33 gtr rear wing with carbon end caps. very good condition, paint is not factory..$350.00
Genuine gtr 2 piece side skirts in very good condition, a few scrapes along the bottom but no damage..$150.00
GTR front drive shaft in good coondition...$100.00
Genuine 33 gtr rear sway bar, good upb
grade for 33 gtst..$50.00
Dual A pillar pod mount..$50.00
steering column surround..$25.00
Passenger kick panel...$15.00
GTR bovs on genuine gtr pipe...125.00
BM 57 33gtr brake master cylinder..$75.00
33gtr clutch slabe..$50.00
33 gtr power steering reservoir..$50.00
33 gtr ABS unit..$250.00
33 gtr injector resistor pack,,$75.00
33GTR buar raisers...$100.00
33 GTR bonnet hinges..$50.00
Drivers side window switches (2) ..$100.00 each
Custom washer bottle catch can combo in polished alloy..$125.00
33 GTR door cards front and rear really good condition with one small blemish on passenger door (see pic)..$150.00
Front passenger guard with a couple of very small dents, easily repairable..$75.00
GTR sump with Cusco 1.5 way diff. Diff is near new, Sump has a hairline crack but will be repaired prior to sale..$650.00
33gtr power steering Wrack in very good condition...$100.00
Complete 33 GTR kaframe with Vspec diff, all arms knuckles and handbrakes. $650.00
GTR centre console cup holder with GTR badge..$25.00
post-35087-0-21341800-1345957848_thumb.jpgpost-35087-0-47272900-1345957861_thumb.jpgpost-35087-0-87899600-1345957879_thumb.jpg
AS new Jim berry full monty clutch and pressure plate. This clutch has done less than 2 hours work and all machine marks are still visible, Would definitely suit new buyer..$800.00
Other items without pics..full set of front and rear prince mats in very good nick...$100.00
Attessa pump..$200.00
Genuine facory rear bar in excellent condition..$150.00
Larger items are pickup, Most items I will post at buyers expense.
Should you require any other info please contact me.
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/
Hi, Would you have the sub loom for the 2 knock sensosr,idling control, oil temp etc. that end up with a grey 8 pin plug onto the plug in the front part of the fuel rail?
Thanks
Alex 0433878905
https://www.sau.com.au/forums/topic/407854-33gtr-part-out/#findComment-6531969
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
