Yep, hahaha, but if I have no luck finding it then i guess that's what I have to do
Anyone know which headers I should get for my 300GT?
I have a mate in the states that had Momentum headers on his G35 but he has since taken it off and parted it out cause he bought a G37. He did say they were good but not sure :/
Plenum spacer, Crank Pulley w/ new belts, Throttle Body Spacer installed today!
By the RevZone guys, took them approximately 7 hours (They said there was issues with taking off the EGR belt), they've also cleaned up my plenum, apparently was the worst build up they've ever seen.
Paid $616, they repaired my plenum threads and studs, topped up my coolant and apparently I had a leak in my cooling system, all fixed up now, idles so much better!
Next mod will be the KuRookie front bar and NisRookie sides then finally some BC racing coils!
Not too sure if he said belt or vent :P Nope don't think so, invoice just states:
Remove and replace intake spacer (owner supplied)
Remove and replace crank pulley (owner supplied)
Repair intake plenum threads and studs
Pressure clean intake plenum
Bleed cooling system
Martini V-series Type A Coolant
Engine De greaser
Edited by itsRICHARD
yeah, I was thinking that but I wasn't sure.. LOL, now i look like an idiot hahah
hmm, I heard quite a lot of good things about revzone though, decided to give it a shot there
Yeah, I had the same issue, otherwise I would of done it myself and saved some $$, not quite a mechanically minded person though, still learning hahah
  • 3 weeks later...
Cleaned the throttle body yesterday and having high rpm issues on start up, roughly 2000 then drops to 800 and bounces up to 1400 and back down to 650, also random rpm spikes when foot is off the accel while driving, going to try the relearn process soon.
Can anybody confirm if the crank pulley in this combo will fit on my VQ30DD?
http://www.conceptzp...7123.243.124.42
Having trouble finding the recommended spark plug for my 300GT 'NGK LFR5AQP'
However the 'LFR5AIX-11' is available on CZP but their not recommended for the 300GT.. but the 250GT and 350GT uses this spark plug..
This is driving me nuts! Too less info on the 300GT :(
I’m going to assume you unplugged the throttle body from the car. bummer i haven't been on the forum for a while. if you unplug it you have to do the relearn procedure or it will act up as you said. i clean my throttle body every second service and all i do is get some carby cleaner and remove the 4 intake, then unscrew the 4 bolts that hold it down (make sure not to lose the mettal wassher ) get a microfibre cloth and clean the throttle body and the little butterfly inside it. ( all this without disconnecting it from the car.and have a read of the G35 forums as there's heaps of info on the matter: http://g35driver.com/forums/g35-sedan-v35-2003-06/402719-how-i-fixed-my-throttle-body-after-cleaning.html
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
