Hi all looking for some insight into the emblems for my 370gt. Was wondering if the US G37 Infiniti Emblem should be compatible with the JDM 370GT front grille? Was told they would fit but once i got it, there has been a lot of resistance just to place the emblem in place, but it would not clip in at all. Has anyone else had any luck? maybe im doing it wrong? the Original Nissan emblem fits perfect, no resistance and just pops into place. It fills like to me that they are not interchangeable.
Any input is appreciated, especially with photos!
Thanks
https://www.sau.com.au/forums/topic/408157-v36-grille-emblem-nissan-v-infiniti/
They are not interchangeable - the Nissan and Inifniti badges are different sizes. Even on V35s you have to buy a different front grille in order to fit the G35 badging.
Are you sure about that? Because i placed an order for this:
http://www.ebay.com....cvip=true&rt=nc
Was under the impression that they should fit on our V35 given from what i was told.
Edited by Marshan
^^^ so seriously, the OP has said he fell for some idiot telling him that an Infiniti badge will direct fit a V35 (like you have), he has it in his hand and sure enough it won't fit, and you want to dispute it?
God damn it, i was told it would fit too.....order was shipped 4 days ago. Too late now i suppose.
If you are handy with a dremel you might make it fit :)
And Seano you CAN'T road register a G35 (unless you are talking the convertible V36 version out of Europe). And when Infiniti start selling cars in Aus shortly you will see lots of people putting Infiniti badging on their V35s ..... once people start considering Infiniti to be a premium brand, people will respect it more. A lot like people putting Lexus badging on their Soarers.
Actually, I just found out from the seller that the one I purchased was not for a G37 Coupe but for a G37 sedan and apparently they have different grilles. So there might still be hope yet, just emailed an infiniti dealer in the states to confirm.
It will as long as you match the body type. That is, be sure to get the coupe badge or the sedan badge. I've got the 2009 370GT coupe and I made sure that the grille emblem I got was the badge for a 2010 G37 coupe, as that's the equivalent model. Mine clipped straight on, no problem. The only thing I needed to do though was to get out the polish and rub away some of the baked in dirt that was trapped behind the Nissan Hamburger, which is a little wider than the Infiniti Mt Fuji.
[Edit]: I should've read the rest of the thread. Seems you've already been told the same reason. :)
For what it's worth, here's the one I bought and it was from the same seller: http://www.ebay.com.au/itm/OEM-INFINITI-G37-COUPE-2DR-FRONT-GRILLE-EMBLEM-CHROME-/280951353466?pt=Motors_Car_Truck_Parts_Accessories&hash=item416a01707a
Edited by The Max
I'll dispute it, from experience but only on a V36. I don't know about a V35 though given the OP was talking about a 370GT which would make it a V36. :)
For what it's worth, here's the one I bought and it was from the same seller: http://www.ebay.com....=item416a01707a
Thanks, im also buying through OC Infiniti and suitability has been confirmed
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
