Hi all,
Pop quiz - what should the oil temperature gauge on an R32 GT-R read?
Mine sits at the bottom (70 degrees) all of the time. Is this normal or abnormal? If it's not right, where should I start looking for the fault?
Cheers!
Mike T
Probably not working, they aren't known for their accuracy anyway, it should read the approx same temperature as the coolant temp (-/+ 5C) because oil and water both go through the oil/water separator (factory oil warmer/cooler). You should be seeing the needle starting to rise above 70C about 10 minutes into a trip.
I can think of 4 things it could be.
#1 Gauge isn't working
#2 Oil temp sensor isn't working (might work with a good cleanout)
#3 The wiring between the above 2 is damaged somewhere
#4 Thermostat is stuck open or you have a Nismo thermostat (opens at 62C) which isn't allowing the coolant (and oil because of the oil/water separator) to get up to temp
Cool - thanks! I hadn't thought of the relationship between the oil and water temperature.
On a related note then, i'm amazed at how quickly the water temperature gets up to the centre of that gauge's range. It's only a minute or so, two at the most and then it's at operating temperature. It then remains there solid as a rock.
Again, is this normal RB26DETT behaviour? To the best of my knowledge it's an unmolested stock standard engine (R32 V-Spec... so it should be stock) with only 67,000 on the clock.
Apologies if all of this is a bit 'noob'ish' - I've never owned a Nissan RB engine before. I'm also not a mechanic (I'm a construction professional).
Mine sits at 70 when warm, always. I use that as the "its ok to go hard now" mark, as you know the motor is properly up to temp (unlike the water temp gauge). On track days i saw it go as high as 110 before i got an oil cooler.
I have an aftermarket oil cooler which is controlled by a thermostat, but I still have the factory oil warmer/cooler fitted. Once the coolant is fully up to temp (85C) takes about 15mins of driving in summer, or 20+mins in winter, my oil will sit on approx 85C (factory gauge). But the oil temp always lags behind the coolant temp by about 5C, if my coolant temp is 75C for example, my oil temp will be 70C (which I'm assuming is the work of the factory oil warmer matching the oil temp to the coolant temp)
Cool... Did you use a Nissan cooler, or did you go aftemarket?
Coolant temp wise, does yours get up to temperature really quickly?
I have the factory nissan oil/coolant heat exchanger in place, and an HKS kit with filter relocator.
Re: coolant, the gauge gets to the gauge midpoint quickly - but remember what moodles said about that.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
