Hi all, got my R34 sedan for sale.
I seriously do not want to sell this car, but i just got a job in a mine that is fly in fly out so i wont ever get time to use it anymore/will have no room for it, so selling it makes more sense than not.
I leave on October 1st so i need to try and sell it before then.
Has just over 43,000kms. The engine i am not sure of, it was replaced in June.
Rego'd till December 2012. You might have to get your own RWC because of my time restriction.
Power: 224.5rwkw (301hp) @16psi (Tuned by East Coast Customs - dyno sheet provided)
PRICE: $18,000 or best offer.
Contact: Ben on 0431627487 (please sms only, i will reply when i get a chance) or email:[email protected]
Modifications:
* High flowed turbo by ETS (Eastern Turbocharger Services) with Garrett TA34 internals.
* NISTUNE ecu
* Bosch 550cc injectors
* Warlbro GSS342 255lph 550hp fuel pump
* Splifire coil packs
* Turbosmart boost controller
* Tomei adjustable fuel pressure regulator
* Front mount intercooler
* Z32 air flow meter
* Pod filter
* 3" turbo back X-Force exhaust, high flow cat and 7" stainless canon (some of the exhaust is stainless)
* DEED racing adjustable coilovers
* 19" Manary wheels, these are new
* URAS bodykit (rear apron is authentic, the front and skirts are not) The kit is newly installed and sprayed as of August 2012, done by Gary at Dents 'n' Detail Noosa
* V-Force fins vortex generators
* Nismo clear front indicators
* HKS turbo timer
* Spitfire boost gauge
* Dark tint on rear window, and both back seat windows
* Drift brand drivers bucket seat - Queensland mod plated
* All gaskets, seals, belts etc are new as of June 2012
* Brand new plugs, oil (Nulon 0W - 50W) and oil filter as of August 2012 (done about 250kms since change).
Comes with a second auto gearbox that is shift kitted.
Also comes with spare 'Drift' brand bucket seat.
Hi mate :)
I have never personally exported a car...but if you know anyone that knows how that works, it could be worth it, not sure on the costs either.
If you wanted to buy the car off me then organize your shipping then your welcome to do so?
  • 3 weeks later...
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
