I am seriously feeling depressed after selling my r33 gtst :( kind of regret it but oh well.
Sold it due to me wanting an R33 GTR.....is the upgrade to a GTR that much of a difference?
be honest lol.
Edited by BOOSTBIG
https://www.sau.com.au/forums/topic/408403-sold-gtst-for-r33-gtrworth-it/
man, based on what you know, and what you see....i think it'll be chalk and cheese.
i've never owned a GTR, but just look at the facts;
2.6 vs 2.5
different heads,
turbos,
TRACTION!
and many other engineering variables.
Go for a test drive in one, and see for yourself, and make up your own opinion of what a GTR is.
Peace out! :woot:
I sold my GTST ages ago to buy a GTR, it's worth it.
Since I've had 3 GTR's with plans to buy another GTR despite my trying to get something else.
Ok thanks heaps guys.
any advice or things I should know about before I purchase a gtr?
any particular model? I am after the R33, but do they differ in terms of specs depending on the year model?
and any difference between a standard gtr and v spec?
thanks guys
You'll just love the R33 GT-R Chris :)
*The V-Spec has a quicker ATTESSA System to activate the front wheels.
*V-Spec is easily recognised by the fins on the rear diff.
*Besides checking for any rust (indicating that the car has lived much of its life near the Japanese coast or been driven on salted roads), do your usual checks as you would on any car.
*I would look for complete history from here as well as Japan &/or receipts.
*Wear and tear should be consistent with the odometer; including driving seat bolster, scratches on steering wheel as well as sun damage, scratches on ignition barrel, scratches under driver's door handle, scratches on door sill, gear knob condition (but that's often changed anyway), and ageing of the windscreen wiper arms.
*Electrics are usually good on the R33 GT-R.
*Brakes should be fine also, but need checking if tracked very much
*Do slow circles clockwise and anticlockwise with windows down to listen for CV clicking
*Check where the car is usually parked overnight to see if there are any oil drips. But put it up on a hoist anyway to check seepage
*Compression test is recommended
*Series II will have 2 airbags & later models may have Xenon headlights
*Don't be surprised about different quality rides in different GT-Rs since there is a wide variety of coilovers out there with different spring rates and settings
thank you so much for that post man. appreciate it.
do you guys recommend I put in forged pistons as soon as possible?
You'll only need forgies if you're chasing some big power (300ish at the wheels).
You're probably best waiting until the donk needs a rebuild before you go to that expense.
Don't let me stop you but you're looking at a sizeable bill even if you can do it yourself.
Personally I'd work up to it. Mine came with them so happy days!
Could be worth looking for one that has already had engine work. What has been spent on top of the value of the car will be waaaay less than what it would cost you to get done.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
