Can someone please tell me the difference between these two cars, because I honestly can't see the difference.
1998 NISSAN SKYLINE R34 25GT
2.5lt Inline 6, N/A.
1998 NISSAN SKYLINE R34 GT
2.0lt Inline 6, N/A.
https://www.sau.com.au/forums/topic/408483-confusion/#findComment-6516869
I could probably talk it down to 10gs.
http://www.carsales....00&sort=default
You should ask him the same question 40 times about the car with slightly different wording. He'll give you the car for $8,000 to avoid any further discussion.
https://www.sau.com.au/forums/topic/408483-confusion/#findComment-6517732
I also recommend that you ring him up several times using a differant name. Then visit him and ask that question. It is ok if you turn up to meet him wearing a name tag with your real first name as long as you wear a cunning disguise.
Edited by *LOACH*
https://www.sau.com.au/forums/topic/408483-confusion/#findComment-6517747
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
    • Haha, that's so true. Minimal plans quickly turn into a full transformation, especially when you see what others are doing
