Hi all, my names Chris. Great forum, found a lot of usefull info on here. Been a member for a while but never introduced myself. I'm from toowoomba QLD and I own a r32 4 door as my daily. Had it for about 18 months now, haven't really done much to it.
Std rb20 turbo, 11 psi with boost tee
3" turbo back exhaust
Cusco coilovers
R33 front brakes
Gtr front bar
Side skirts and rear pods
That's about it really.
https://www.sau.com.au/forums/topic/408637-me-and-my-4-door/
  • 1 month later...
