Dear Seniors
I just got my R33 GTST and am intending to convert it from AT to MT by December.
I am also going to tune up the car to a Drift Ready state maintaining street drivability.
I have the intention to do the following in due course after my MT and Exhaust initial mod and am looking at advice on Viability and availability:
1. Handling - the standard stuff like Coil over, Tower Bars and ARB. Looking for recommendations. Plus Advice if member braces are required?
2. Handling - Looking for advice if it is advicable to remove HICAS. I am looking to change my steering to one with quick release BOSS but can give that up if HICAS is more recommended.
3. Turbo - I am thinking of a Garette GT0376 or similar (Prefer Ball Bearing so the IHI comparable might be a good alternative) Looking at 1.2bar Boost Max... Any Engine mods required or recommended? Stut bolts? Pistons and Con Rods? Actually I might lower the boost if i need to take the engine apart.
4. Intercooler - the natural thing with Turbo would be a totally trick FMIC... Please recommend...
5. Auxillary parts - Fuel Injectors, Surge Tanks, External Pumps...
6. Most important part - The Brains!!! What ECU is popular here? Where can I get competent and affordable tuners? Where is a good hub dyno that wun cost me an arm or a leg? I am familiar with most modern ECUs like MoTec, Power FC, and F Con V Pro... I am unable to touch Motec and F Con due to the large amount of wiring works, Power FC due to computer connector... So I'll probably need someone to install and tune...
Glad to receive any advice...
Cheers
https://www.sau.com.au/forums/topic/408704-noob-seeking-advice/
If you just got the car I recommend you do the manual conv and then work on the handling side of things.
IMO no point in boosting the power until you know how to drift it, otherwise you just play tag with the walls. I have a friend who has just started drifting... his starter car is an R32 with an RB20E which is perfect. Simple mods will be fine, FMIC, pod filter, new brake pads/fluid are good too and some decent suspension.
If the 33 runs electronic HICAS you can remove the steering rack and replace it with a lock bar. Some places sell collars that will lock the steering rack but you're better off replacing the whole thing with a lock bar.
Mate, if your free tomorrow night head up to the track for the drift prac that's on.
If you ask for the drift trainer named Marc the officials can point you in my direction and you can get an idea of the basics from there.
As mentioned above leave the power mods for now, make the car drive right and sto right then move onto that stuff. I would also add a fixed back seat to the list for one of your first mods, it makes a bigger difference than you would think!
Also www.driftwa.com.au
I was at the back section of the track all night and yeah pretty busy up there. We had about 15 cars just in the training area!
Usually one a month at this point mate, check the WASCC web page for the calendar or like WADrift on FB ;)
Tha mate!
I happen to also notice Barbagallo Drift Assault on 30 September and 1 October... I'll be hopping by in the arvo on 30 September but I'll have to miss 1 October as I have a class test going on that day...
Cya there if u r there mate...
  • 3 weeks later...
You want to drift - sell it, buy a 32
You are talking about spending a lot of money, those parts aren't cheap, then add in labour
If it needs to be a 33, see how much a manual costs, compare the cost to what you will be paying (gearbox, shifter, decent clutch, pedal boxes and pedals, master and slave cylinder - prob going to cost you 3k or more in parts
But a 32 is much much better for sliding than a 33, more fun and cheaper
Just my opinion anyways (havin owned both and drifted both)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
