Hi All,
Just wanted to dropped in and say hi, just purchased an R35 from WA from Northside Nissan. Still waiting for the car to be shipped to Cabramatta NSW, which will take around 9-10 days. Ordered my custom plates, black background with orange text - HZRDUS which hopefully arrive around that time too. Just ordered a set of ADV.1s from Michael at Acute Performance, that... will take around 3 months. Anyways, if anyone sees a matte black GTR rolling around cabramatta... beep and wave.
Laters...
Leng
https://www.sau.com.au/forums/topic/408731-newest-r35-owner-hzrdus/
  • Replies 49
Posted Images
If I roam around Cabramatta, I'll drive slowly because...
a) I don't want to be T-boned
b) I'm impressed with a black R35 & I might espy one
c) I'd like to meet the owner
d) All of the above = Yeah baby!
haha yea, was lucky, i was only on the market for about a week before deciding to get that one. havent even seen the car yet. i just assumed that its in good condition as dealers have to disclose any dmg or repairs required, considering its an interstate purchase, if i cant get the thing rego'd, im sending it straight back, but i doubt that will be the case. Northside Nissan have been pretty upfront with the information and seem to be a nice bunch of guys. any hoots, ill post pics once i get the car.
no pics yet, still waiting for the car. its in melbourne atm will arrive on saturday, pick up on monday. ill post pics when i get the car. rims are a few more weeks away... cant wait to slap the wheels on!!
next thing is some wet carbon body kit parts to replace the OEM kit.
Sounds great mate
Had my ADVs for well over a year now but they are still rare enough on the GTR
Re carbon lower panels, you can't beat zele. Fit and finish is spot on. Ignore the cheaper Chinese eBay fakes
Edited by domino_z
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
