Transporting Car From Victoria To Queensland
I have purchased a car in Victoria and am looking to drive it up to Queensland. The only problem with this is that the car is unregistered however, it will have a RWC. I have been given a few options of ways to bring this car back.
1. Get a Unregistered car permit, allowing me to drive back with an unregistered, yet roadworthy car.
2. Pay the seller to register the car again and get the registration swapped into my name, transport/drive the car to QLD. Do a RWC in QLD (non-qld RWCs are not accepted)
- Register the car and pay the usual fees (rego, stamp duty, plates...).
- Hand in the VIC plates to Queensland Transport. They'll issue a receipt. Fill out a refund form (downloadable from the vicroads website), attach the receipt, and send it to vicroads.
- Wait 4 weeks for the cheque.
3. Shipping the car back (expensive).
4 I have heard of someone, somehow registering the car in Queensland, taking down the Queensland plates, putting them on the car then driving it back.
If anyone has done this or has any ideas of what the best course of action is let me know.
2 or 3 sound like the best options imo
1 is generally for taking cars to mechanics etc, not interstate
and 4 sounds a little dodgy tbh, don't you need the car to be sighted in QLD for it to be registered too?
i would leave it with a friend, fly back.
borrow a friend with a car that has the ability to tow and a car trailor(if not hire one)
pay your friend to drive down(should be cheaper than a towy)
pick up, drive back!
if your really trying to avoid cost that is.
When i bought a unreg car i just brang my own plates thats also registered to car; same make and model, for example if im buying a r32 skyline ill bring my r33 skyline plates
put it on the car and drove it home and hope not to get pulled over for them to check the vin haha
or
if u want to do the legit way trailer it all the way as above
but since ur getting a vic rwc with the car may aswell use it to rego it here (as u can't use the vic rwc in qld) and drive it back with vic plates and do the transfer to qld plates later
4. Looks like a dodgie way of getting rego as normaly it needs to be inspected but if u got mates willin to do it for you then why not hey?
So i would go with option 2.
I also have sydney buyer coming to pickup my s13 its unregistered but he says hes already doing rego in nsw, he will be bringing the plates down so i guess that would be option 4 lol but idk as long as the car is gone, he already left me a deposit.
Edited by Johnie
You will get raped driving it unregistered interstate .... also if you go the legit permit way you need 3 (QLD,NSW and VIC) as cops will not accept one from another state (dad got stung taking my 32 from qld into nsw with a qld permit .... no good)
Not to mention you wouldnt be insured ..... in the case of you hitting a roo or something eles
Ideally trailor or not so ideally, courier ..... wouldnt be much more cash then paying petrol and the time/effort if you drove it back
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
