  • Replies 87
jdmst forum, where they do nothing but hellaflush, meet in carparks and play with remote control cars.
Good job, save up for a real car not some homo honda with stupid offset wheels and camber that does nothing but ruin the car
Well, I currently drive a civic but have done NOTHING to it, stock as a rock - seriously what's the point? JDM is so....pointless.
Anyway. anyone know why 2000 or 2001 black GTTs (manual) are so hard to find? and, say, can anyone give me a rough estimate of how much a total stage 1 tune as specified here, will cost assuming I have a stock car? help appreciated and thanks in advance!
including ecu, quite a bit - examples;
exhaust may be $600-1k
intake - fark that, leave it as stock box but change filter to something decent. $100
boost - go with an electronic boost controller, can probably get one for $300 or so
ECU - anywhere from 1-2k for ECU, then tuning time.
all in all, not cheap.
I've got a 33 gtst with exhaust, new panel filter and boost controller on 10psi and i'm running 190rwkw at full song, albeit with massive rich and retard in the middle (goes nuts once it's past that though). installing SAFC to smooth that out.
By no means is it the quickest car out there, but for the road, it's more than enough - you wanna stay on the good side of the law.
I like you already, just like my V6 accord, smashes little rice boys in their worked Civics, Integras ra ra ra.. I just leave it stock, it's great the way it is.. I have my fridge, I mean R33 for the mods
Fark that.
Chop springs.
Speed holes diffuser rear bumper.
Sticker bombed panels.
Stanced.
Then hardpark that farker.
@cpd thanks for that, easily another 2k on top of the car + any other things which need fixing up at the time of purchase. damn. better hope I find a cheap one/one that doesn't need too much fixing!
@MBS206 funnily enough, after deciding I wanted a 34, tried to find my copy of GT5 just to have some fun and......cant find it. can't even practice. sad.
@b00bs hahahaha. can't wait to get my boat. will be bigger than your fridge!
@ tai1or made - yeah....don't really understand much of what you said.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
