hi guys,
this is impressive - an r35gtr with an exhaust & retune is quicker than a current spec Gsxr1000.
I used to race bikes & I can see that the rider knows how to ride so he is really pushing his bike:
I find this incredible as the bike has 1:1 power to weight ratio - all the more kudo's to the mighty r35gtr!!!
Enjoy :)
https://www.sau.com.au/forums/topic/409322-i-thought-id-never-see-the-day/
should be able to take down a litre bike from rest with a full bolt on r35 and good lc traction
but roll on comparisons don't really make sense in aus due to our speed limits and what you stand to lose if/when get caught, nor can we type our own disclaimer filmed in mexico
Edited by domino_z
It must be mentioned that the guy on the bike has got no stick and to make a GTR go fast from 60ks takes no skill whatsoever.
Put me up against a GTR on my R1 and it'll be close to 120 then I'll stomp it to 250ish then The GTR will start to catch me once we pass ~260-270kph and I'll hit a wall at ~290 where as the GTR will be leaving me at ~30kph and I won't see it again till it gets bored and slows down.
I doubt that race hit 250 so the gixxer should have been comfortably in front but I have a feeling the dude in shorts and a tshirt hasn't got much of a clue.
What yr model is your r1?
Yrs ago I had a 99r1 with work done it, making 145rwhp...I ran that against my r32gtr which had 365awkw and I couldn't get away from it on the bike and we were rolling from about 80km to way over 200kmh.
On that old dinosaur I got it up to 309kmh but that was it...I wouldn't accelerate past that point.
It is dark but u when u get a clear view of the bikes headlight, u know the race is over :)
Riding a bike on roll on is like a car, no real art other than change just under the limiter.
It is going to be subjective at the end of the day Which is quicker but for those who ride bikes and understand howbfast they are, it is phenominal to see a near stock gtr play in the same field.
it's dark, you can barely see anything and all you can hear is the gtr. I do not know how you can tell if the rider knows how to ride the bike.
I've been riding for 16 years and am yet to meet a single person who rides in shorts and a tshirt who knows how to bang.
Edited by Cowboy1600
Precisely. 365awkw is somewhere in the vicinity of 600hp. That's 70 more than an R35 and in a car which is some 300+kg lighter than an R35.
A newish Gixxer 1000 should school a GTR from 60-250ish. From there the R35 stomps the gixxer.
Well, actually it's not going to be subjective.
2011 GTR - 0-200 in ~11.1 seconds - http://www.germancarforum.com/community/threads/first-performance-test-2011-nissan-gt-r.36376/
2006 Gixxer 1000 - ~5.5 seconds - http://www.firstpost.com/topic/organization/suzuki-motor-gsxr-1000-k6-0-250-kmh-acceleration-test-gopro-hd-video-4VrYvYUoC08-85101-9.html
That's objective.
And it's possible to miss a gear on the bike, not so in a GTR, meaning you need some semblance of skill to do it.
Also -
- the GTR got the jump and still got spanked in the first race. Edited by Cowboy1600
I cant see the link to that gixxer? The best 0-200 I could find on the gsxr was 7.5sec.
Either that gtr had more work done to it or maybe the bike was a 750 or 600?
My last bike was in fact a k6 with arata titanium full system and power commander - farken monster made 173.5rwhp! I could pick up the front eheel in 4th gear at 240kph...man i miss my bikes.
after you threw in the leathers, she didn't have much choice but to colour co'ordinate
u got me there, very cheeky lol
P.S. I never had the chance to thank you for donating the leathers to me
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
