sifting-sideways Posted September 14, 2012 Share Posted September 14, 2012 Hi everyone, i'm having a starting issue with my a31 cefiro, it has a s1 rb25det in it, the issue is, the car has been working fine, but lately the car stopped starting when turning the key to start, it would just wind over happly not firing, the strange thing is as soon as i released the key it would start, like between start and on on the key barrel? its getting worse and some times won't even start after releasing key, any ideas? thanks Link to comment https://www.sau.com.au/forums/topic/409324-starting-issue-will-only-start-when-i-stop-trying-to-crank-over/ Share on other sites More sharing options...
DVS JEZ Posted September 15, 2012 Share Posted September 15, 2012 Could be a few things like -fuel pressure/flow -start signal to ecu is wired up incorrectly -wombat in the airfilter Link to comment https://www.sau.com.au/forums/topic/409324-starting-issue-will-only-start-when-i-stop-trying-to-crank-over/#findComment-6534191 Share on other sites More sharing options...
t_revz Posted September 15, 2012 Share Posted September 15, 2012 Can only be one thing -wombat in the airfilter Or could be a power supply to Ecu fault. Not enough supply while the starter motor is running. Link to comment https://www.sau.com.au/forums/topic/409324-starting-issue-will-only-start-when-i-stop-trying-to-crank-over/#findComment-6534395 Share on other sites More sharing options...
mico Posted September 15, 2012 Share Posted September 15, 2012 dont start it, then it will start ?!?!! Link to comment https://www.sau.com.au/forums/topic/409324-starting-issue-will-only-start-when-i-stop-trying-to-crank-over/#findComment-6534432 Share on other sites More sharing options...
sifting-sideways Posted September 30, 2012 Author Share Posted September 30, 2012 Found the problem, turned out to be the 2 blue relays under the dash, they were faulty, put new ones in and she's a runner thanks for your ideas tho Link to comment https://www.sau.com.au/forums/topic/409324-starting-issue-will-only-start-when-i-stop-trying-to-crank-over/#findComment-6557386 Share on other sites More sharing options...
