  • 3 weeks later...
Hi, Will take front guard liners with air ducts and brake master cylinder with booster.
Pm sent going to SAU Sandown sprint this Satturday. please call /sms 0433878905 to arrange payment and pick up
Alex Braeside 3195
Rear cut (wider quarters) - $1,000
Bonnet - $600
R33 Gtr gearbox - $600
Hubs - $400
Front and rear cradles - $150 each
Lower control arms, front - $120
Fuel tank - $100
Stock R33 Gtr suspension - $300
ABS unit - $200
Stock air box - $250
Intercooler piping - $200
Stock BOVs - $140
Front stock strut brace - $100
Rear stock strut brace - $50
Boot lid with wing - $400
Rear bar - $250
Tail lights - $120 pair
Doors - $300 pair
Excellent condition, does not include interior trims
Door trims - $200 (no window switch)
Window switch - $50 drivers side
Window switch - $50 passenger side
A pillar trims - $50 each
Full set of R33 Gtr floor mats $200 in Excellent condition
Centre console $100 Ecellent condition
Includes Gtr badge
Climate control unit - $40
Triple gauge cluster - $150
Steering wheel - $300
Dash pad - $100
Rear vision mirror - $20
Sun visors - $10 each
Rear seats - $300
Seat belts - $40 each
B/C pillar trims - $50 each
Complete boot interior - $150
Space saver - $100
Rear window - $200 Remove yourself
Set of wipers - $50
Wiper motors - $50
Some other parts available too, just PM me what part your after if it is not listed, and we can sort something out. Negotiable on some parts so ask away.
Quick update guys on what is left and what isn't
Rear cut (wider quarters) - $750
Bonnet - $600
Stock BOVs - $140
Rear bar - $150
Tail lights - $100 pair
Doors - $300 pair $400 with door trims
Door trims - $200
Includes Gtr badge
Rear seats - $150
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
