R33 1993 Silver Manual Shell
This is still registered in vic, so can be registered. Not written off or anything, just stripping a track car.
This is what it comes with:
Engine Bay
No head (have a spare stock head with exhaust studs snapped off inside for free)
Have stock turbo, manifold, intake manifold etc if you like
Block, in good condition, still installed
engine loom
All pumps
Accessories
No air con or lines
Walbro intank pump
No exhaust
Suspension/Driveline
No Gearbox
HSD HR coilovers
Cusco camber arms front and rear
Adjustable toe rods
Adjustable castor arms
Adjustable traction rods
Tie rod ends
Upgraded bushes
Hicas delete bar
Whiteline swaybars
Kaaz 1.5 way diff
Brakes
Dba4000 rotors
bendix ultimate pads
braided brake lines
Wheels
None atm, either will have to find stockies or supply your own
Exterior
Nismo front bar with canards
Nismo sideskirts(not in very good nick)
F1 carbon mirrors
tinted windows
bonnet pins in stock bonnet
stealth wing(modified to fit gt wing)
Interior
stripped interior including sound deadening
everything under the dash stripped(i.e. heater box etc)
stock front seats
still has driver/passenger seat belts, rear view mirror.
Looking for $2000
Have gearbox and other parts advertised separately
Located in sydney
Any q's just ask, probably forget a few things
Pic here
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=378209
there are some more pics in my build thread.
Just to note this still has a full loom, hasn't been played with.
Comes with fuel system aswell which includes:
Walbro intank
1.5lt surge tank
bosch 044 external -
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
