Hey guys,
I recently did a turbo upgrade and everything was fine for a couple of weeks (just a bit rich). Driving home from spectating Powercruise i was getting on the highway and when i pushed the throttle in, it gave a small pop and then started to miss under full throttle.
The car has a Stinger EMS ecu, GTR injectors, GTR fuel pump, Yellow Jacket Coil packs.
So far i have checked/cleaned the plugs (covered in carbon), Taped the coil packs, checked for vaccuum leaks, checked the fuel maps, used a multimeter on the ignitor (wouldnt read anything on ohms)
I have searched this forum and many others for possible causes and solutions and so far have come up with nothing.
Any help would be appreciated, even if you have a spare ignitor/AFM around Brisbane that i can test to rule some things out would be awesome.
Edited by bunnyfart
Massive thanks to SIFTY32 for letting me test his ignitor and coil packs. Nothing changed when i put his on so that rules them out. I ran a data log on my ECU and when i had my foot to the floor with no load the TPS was jumping from 100 (full open) to around 70 - 80 (not full open). My thought process is that the TPS is telling the ECU that my foot isnt to the floor when it actually is.
Is there a decent way to test the TPS with a multimeter?
Do u have an aftermarket throttle body?
I have had 2 cars lately that have had freeplay between the tps and throttle shaft.
Use a multimeter between the Signal wire and the earth wire.
Should read around .5v closed and 4.5v open completely
standard throttle body. Used the multimeter on the 2 wire and got 1.9 ohms but when i started to move the throttle butterfly it made the multimeter turn off until it was returned to closed.
I changed it to V and got 1.0 on closed and again it turned off when it was opened
Edited by bunnyfart
Ok, it seems my missfire has been solved by disconnecting my aftermarket water temp gauge from the 2 wire sensor.
Its running really well now with better fuel consumption and able to rev really easily.
Can anyone explain to me why the water temp sensor would cause such a massive issue with my car?
I never understand people that wire things in without researching.
Yes thet makes perfect sense as the coolant temp sensor is very sensitive to voltage. It even runs its own seperate sensor ground with only a few sensors like TPS and CAS.
Glad u found the issue
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
