  • Replies 40
UPDATED LIST!!! PRICE DROP!!!
various trims $name your price
centre console brackets $1
power steering reservoir minus cap $5
centre dome light without cover $5
driver door loom $5
washer bottle loom $5
number plate lights $5
front windscreen washers $5
ignition/headlight reminder beeper $5
stock rear audio amplifier $5
sun visor clips $5
wiper amp $5
Mirror triangle cover thing - $10
drum brakes (in bits and pieces) $10 for both
Pod filter $10
front reading lights $10
HICAS computer bits $10
blower fan $10
bonnet lining $10
brake booster $10
brake pedal $10
centre console hand brake leather $10
centre console front trim $10
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
hicas steering rack $10
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side kick panel $10
roof lining $10
steering column (minus the bottom part of the shaft) $10
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
alternator - had battery juice spilt on it from the accident, might still work $10
boot rubber seal $10
catalytic convertor sensor $10
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
ignition loom $10
driver side door solonoid $10
flywheel cover $10
open door sensors $10
passenger fog light (lens is ok, plastic a little cracked) $10
various metal sheild bits $10 the lot
wiper switch $20
rear wiper motor $20
cluster surround $20
interior wiring (includes wiring that goes into the boot) $30
rear seat belts $20
hazard/stereo switch $20
outer door handles $20 each
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
castor rod arms $20 each
hicas module $30
side mirrors $40 each (driver's side has a small crack on the side)
front control arms x 2 $40
rear calipers x 2 $70
Passenger side mirror gone!
centre console/handbrake surround gone!
2 x kick panels gone!
passenger side a pillar trim gone!
seat belt bolt covers gone!
passenger side rear seat hand rest panel gone!
  • 1 month later...
The remaining parts have been listed as a $1 NO RESERVE eBay auction - http://cgi.ebay.com....em=261147664144
I want this stuff gone! Happy bidding!!!
Only 3 hours left until the auction closes (see link above) and that's all the parts gone from my wreck! Get your bids in or miss out!
LAST CHANCE!!!!
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
